Ana içeriğe geç
Swagtron T3 Cover Replacement
Salt Önkoşul
Bu sadece bir ön koşul kılavuzudur! Bu kılavuz başka bir prosedürün parçasıdır ve tek başına kullanılması amaçlanmamıştır.
Neye ihtiyacın var
  1. Swagtron T3 Cover Replacement, Cover: adım 1, 2 resimden 1. Swagtron T3 Cover Replacement, Cover: adım 1, 2 resimden 2.
    • Make sure the hoverboard is completely powered off and unplugged from any outlets.
    • Flip the Swagtron so that the footpads are facing the ground.
    • Unscrew the sixteen 9.4 mm Phillips #1 machine screws on the side of the Swagtron that is now facing upwards.
    FixBot'a Sor
    Yorum Ekle
  2. Swagtron T3 Cover Replacement: adım 2, 3 resimden 1. Swagtron T3 Cover Replacement: adım 2, 3 resimden 2. Swagtron T3 Cover Replacement: adım 2, 3 resimden 3.
    • Be careful with the small blue capacitors indicated by the orange box. There are many of these capacitors in the device.
    • Slowly lift the backside cover.
    • Both sides lift up the same way, but the motherboard is under one side and the battery is under the other.
    • Detach the four cables connected to the cover by pinching the connector clips and pulling the cables out:
    • Three cables on the motherboard side.
    • Two red cables with white connectors and one white cable with a white connector.
    • One yellow cable with a black connector on the battery side.
    • After detachment, you should be able to completely remove the backside cover.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Klara Perkins
412 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S13-G3, Forte Spring 2017 Cal Poly, Team S13-G3, Forte Spring 2017 üyesi
CPSU-FORTE-S17S13G3
4 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 22
Her zaman: 5,686
