Ana içeriğe geç
Swann Wi-Fi Indoor Security Camera Infrared LED Replacement
Neye ihtiyacın var
    1. Swann Wi-Fi Indoor Security Camera Infrared LED Replacement, Case: adım 1, 3 resimden 1. Swann Wi-Fi Indoor Security Camera Infrared LED Replacement, Case: adım 1, 3 resimden 2. Swann Wi-Fi Indoor Security Camera Infrared LED Replacement, Case: adım 1, 3 resimden 3.
      • Use the Phillips #0 to remove the screw located on the back of the camera above the mount.
      • Slide the mount out from the bottom of the device.
      FixBot'a Sor
      Yorum Ekle
    2. Swann Wi-Fi Indoor Security Camera Infrared LED Replacement: adım 2, 1 resimden 1.
      • Remove the back of the case by placing a iFixit opening tool underneath the edge of the case and prying it up.
      FixBot'a Sor
      Yorum Ekle
    3. Swann Wi-Fi Indoor Security Camera Infrared LED Replacement: adım 3, 1 resimden 1.
      • Carefully remove the back of the case without pulling the cables connected to the motherboard and the speaker on the back of the case.
      FixBot'a Sor
      Yorum Ekle
    1. Swann Wi-Fi Indoor Security Camera Infrared LED Replacement, Infrared LED: adım 4, 1 resimden 1.
      • Facing the inside of the front case, unscrew the three 2.0 mm Phillips #0 black screws located on the back of the LED ring.
      FixBot'a Sor
      Yorum Ekle
    2. Swann Wi-Fi Indoor Security Camera Infrared LED Replacement: adım 5, 2 resimden 1. Swann Wi-Fi Indoor Security Camera Infrared LED Replacement: adım 5, 2 resimden 2.
      • Release the clip connection connecting the LED ring to the motherboard.
      • Remove the infrared LED assembly.
      FixBot'a Sor
      Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 35
Her zaman: 1,782
