Ana içeriğe geç
Swann Wi-Fi Indoor Security Camera Infrared LED Replacement
Neye ihtiyacın var
  1. Swann Wi-Fi Indoor Security Camera Infrared LED Replacement, Case: adım 1, 3 resimden 1. Swann Wi-Fi Indoor Security Camera Infrared LED Replacement, Case: adım 1, 3 resimden 2. Swann Wi-Fi Indoor Security Camera Infrared LED Replacement, Case: adım 1, 3 resimden 3.
    • Use the Phillips #0 to remove the screw located on the back of the camera above the mount.
    • Slide the mount out from the bottom of the device.
  2. Swann Wi-Fi Indoor Security Camera Infrared LED Replacement: adım 2, 1 resimden 1.
    • Remove the back of the case by placing a iFixit opening tool underneath the edge of the case and prying it up.
  3. Swann Wi-Fi Indoor Security Camera Infrared LED Replacement: adım 3, 1 resimden 1.
    • Carefully remove the back of the case without pulling the cables connected to the motherboard and the speaker on the back of the case.
  4. Swann Wi-Fi Indoor Security Camera Infrared LED Replacement, Infrared LED: adım 4, 1 resimden 1.
    • Facing the inside of the front case, unscrew the three 2.0 mm Phillips #0 black screws located on the back of the LED ring.
  5. Swann Wi-Fi Indoor Security Camera Infrared LED Replacement: adım 5, 2 resimden 1. Swann Wi-Fi Indoor Security Camera Infrared LED Replacement: adım 5, 2 resimden 2.
    • Release the clip connection connecting the LED ring to the motherboard.
    • Remove the infrared LED assembly.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 35
Her zaman: 1,325
