Ana içeriğe geç
Swann Wi-Fi Indoor Security Camera Microphone Replacement
Neye ihtiyacın var
  1. Swann Wi-Fi Indoor Security Camera Microphone Replacement, Case: adım 1, 3 resimden 1. Swann Wi-Fi Indoor Security Camera Microphone Replacement, Case: adım 1, 3 resimden 2. Swann Wi-Fi Indoor Security Camera Microphone Replacement, Case: adım 1, 3 resimden 3.
    • Use the Phillips #0 to remove the screw located on the back of the camera above the mount.
    • Slide the mount out from the bottom of the device.
  2. Swann Wi-Fi Indoor Security Camera Microphone Replacement: adım 2, 1 resimden 1.
    • Remove the back of the case by placing a iFixit opening tool underneath the edge of the case and prying it up.
  3. Swann Wi-Fi Indoor Security Camera Microphone Replacement: adım 3, 1 resimden 1.
    • Carefully remove the back of the case without pulling the cables connected to the motherboard and the speaker on the back of the case.
  4. Swann Wi-Fi Indoor Security Camera Microphone Replacement, Microphone: adım 4, 3 resimden 1. Swann Wi-Fi Indoor Security Camera Microphone Replacement, Microphone: adım 4, 3 resimden 2. Swann Wi-Fi Indoor Security Camera Microphone Replacement, Microphone: adım 4, 3 resimden 3.
    • Locate microphone and pull to dislodge from the holder.
    • Disconnect the connector located on the main board to finish disconnecting the microphone.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 815
