Ana içeriğe geç
Swann Wi-Fi Indoor Security Camera SD Card Replacement
Neye ihtiyacın var
  1. Swann Wi-Fi Indoor Security Camera SD Card Replacement, Case: adım 1, 3 resimden 1. Swann Wi-Fi Indoor Security Camera SD Card Replacement, Case: adım 1, 3 resimden 2. Swann Wi-Fi Indoor Security Camera SD Card Replacement, Case: adım 1, 3 resimden 3.
    • Use the Phillips #0 to remove the screw located on the back of the camera above the mount.
    • Slide the mount out from the bottom of the device.
  2. Swann Wi-Fi Indoor Security Camera SD Card Replacement: adım 2, 1 resimden 1.
    • Remove the back of the case by placing a iFixit opening tool underneath the edge of the case and prying it up.
  3. Swann Wi-Fi Indoor Security Camera SD Card Replacement: adım 3, 1 resimden 1.
    • Carefully remove the back of the case without pulling the cables connected to the motherboard and the speaker on the back of the case.
  4. Swann Wi-Fi Indoor Security Camera SD Card Replacement, SD Card: adım 4, 3 resimden 1. Swann Wi-Fi Indoor Security Camera SD Card Replacement, SD Card: adım 4, 3 resimden 2. Swann Wi-Fi Indoor Security Camera SD Card Replacement, SD Card: adım 4, 3 resimden 3.
    • Facing the front of the camera, remove the four 2.0 mm Phillips #0 black screws that hold the back of the motherboard to the case.
  5. Swann Wi-Fi Indoor Security Camera SD Card Replacement: adım 5, 1 resimden 1.
    • With the motherboard removed, flip it over and remove the SD card by pushing in the SD card, releasing it.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 8
Son 30 gün: 25
Her zaman: 1,485
