Ana içeriğe geç
Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement
Neye ihtiyacın var
  1. Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement, Case: adım 1, 3 resimden 1. Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement, Case: adım 1, 3 resimden 2. Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement, Case: adım 1, 3 resimden 3.
    • Use the Phillips #0 to remove the screw located on the back of the camera above the mount.
    • Slide the mount out from the bottom of the device.
  2. Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement: adım 2, 1 resimden 1.
    • Remove the back of the case by placing a iFixit opening tool underneath the edge of the case and prying it up.
  3. Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement: adım 3, 1 resimden 1.
    • Carefully remove the back of the case without pulling the cables connected to the motherboard and the speaker on the back of the case.
  4. Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement, Camera Lens: adım 4, 2 resimden 1. Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement, Camera Lens: adım 4, 2 resimden 2.
    • Facing the front of the camera, remove the four 2.0 mm Phillips #0 black screws that hold the back of the motherboard to the case.
    • Release the four camera cable connections on the motherboard.
  5. Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement: adım 5, 1 resimden 1.
    • Facing the back of the motherboard, remove the two 2.0 mm Phillips #0 screws connecting the camera to the motherboard.
Sonuç
1Rehber Yorum
is there a place i can buy a replacement lens for my swann security camera please
sn 10050062001244
Sonny Jobe - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 19
Her zaman: 1,271
