Ana içeriğe geç
Switch Pro Controller Case Replacement
Neye ihtiyacın var
  1. Switch Pro Controller Case Replacement, Remove the screws: adım 1, 1 resimden 1.
    • Flip the controller over so the model stickers face the ceiling.
    • Use a JIS #00 screwdriver to remove the two black 8.4 mm screws that secure the handles, located at the ends of the handles.
    FixBot'a Sor
    Yorum Ekle
  2. Switch Pro Controller Case Replacement, Remove the handle covers: adım 2, 3 resimden 1. Switch Pro Controller Case Replacement, Remove the handle covers: adım 2, 3 resimden 2. Switch Pro Controller Case Replacement, Remove the handle covers: adım 2, 3 resimden 3.
    • Carefully remove the handle covers by pulling them away from the main body.
    FixBot'a Sor
    Yorum Ekle
  3. Switch Pro Controller Case Replacement, Remove the screws: adım 3, 1 resimden 1.
    • Use a JIS #00 screwdriver to remove the four silver 6.8 mm screws that secure the clear back plastic cover.
    FixBot'a Sor
    Yorum Ekle
  4. Switch Pro Controller Case Replacement, Unclip the plastic cover: adım 4, 3 resimden 1. Switch Pro Controller Case Replacement, Unclip the plastic cover: adım 4, 3 resimden 2. Switch Pro Controller Case Replacement, Unclip the plastic cover: adım 4, 3 resimden 3.
    • Carefully pry away the clear plastic cover using your fingernail.
    FixBot'a Sor
    Yorum Ekle
  5. Switch Pro Controller Case Replacement, Remove the clear plastic cover: adım 5, 1 resimden 1.
    • Remove the clear plastic cover.
    FixBot'a Sor
    Yorum Ekle
  6. Switch Pro Controller Case Replacement, Remove the battery: adım 6, 3 resimden 1. Switch Pro Controller Case Replacement, Remove the battery: adım 6, 3 resimden 2. Switch Pro Controller Case Replacement, Remove the battery: adım 6, 3 resimden 3.
    • Remove the lithium-ion battery by using a fingernail or plastic opening tool to pry it up on the left side.
    • Only a small amount of force is needed.
    FixBot'a Sor
    Yorum Ekle
  7. Switch Pro Controller Case Replacement, Remove the screws: adım 7, 3 resimden 1. Switch Pro Controller Case Replacement, Remove the screws: adım 7, 3 resimden 2. Switch Pro Controller Case Replacement, Remove the screws: adım 7, 3 resimden 3.
    • Use a Phillips #1 screwdriver to remove the five 5 mm screws from the back of the controller.
    • The two case screws above the handgrips and the single case screw below the battery bay have a shallow seat. These three screws can be easily removed.
    • The two case screws adjacent to the ZR and ZL shoulder buttons have a deep seat. Use an extension or a narrow PH1 Phillips screwdriver with a longer shaft to reach these screws.
    FixBot'a Sor
    Yorum Ekle
  8. Switch Pro Controller Case Replacement: adım 8, 3 resimden 1. Switch Pro Controller Case Replacement: adım 8, 3 resimden 2. Switch Pro Controller Case Replacement: adım 8, 3 resimden 3.
    • There's an adhesive pad located in the center of each handle. It will require a bit of force to pry away the front cover, but be mindful of the attached ribbon cable.
    • Delicately take off the plastic cover from the controller.
    • Don't completely remove the front cover just yet, as it's still attached to the motherboard via a white ribbon cable.
    FixBot'a Sor
    Yorum Ekle
  9. Switch Pro Controller Case Replacement, Open the flap: adım 9, 2 resimden 1. Switch Pro Controller Case Replacement, Open the flap: adım 9, 2 resimden 2.
    • Use the tip of an opening pick to open the black flap of the ZIF connector by pushing it upwards.
    FixBot'a Sor
    Yorum Ekle
  10. Switch Pro Controller Case Replacement, Disconnect the interconnect cable: adım 10, 2 resimden 1. Switch Pro Controller Case Replacement, Disconnect the interconnect cable: adım 10, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use your fingers or a pair of blunt nose tweezers to disconnect the interconnect cable from its connector.
    FixBot'a Sor
    Yorum Ekle
  11. Switch Pro Controller Case Replacement, Remove the front case: adım 11, 1 resimden 1.
    • Remove the front case.
    FixBot'a Sor
    Yorum Ekle
Sonuç
22 farklı kişi bu kılavuzu tamamladı.
3Kılavuz Yorumları
I wondered why Xbox X controllers grips were difficult to remove and also make a squeak sound when the plastic part is not closing properly but a double-sided tape should do it...
Nicholin V - Yanıt Paylaş
Disassembly was fine, but reassembly was a bit trickier. Removing the front casing from the chassis as in step 8 required a bit of force, since it seemed like the two were clipped together. Putting the two together, I can't seem to find where exactly that clipping connection was. I'd ignore it and move on to the screws, but it doesn't fit flush and I'm left with this narrow gap at the top that seems to be causing trouble. Any idea where I should be looking/applying pressure?
winter - Yanıt Paylaş
At step eight, the easiest way to separate the two halves is to use your triangle pry tool, on the sides, underneath where the handle covers are, on both sides. I thought that I had missed a screw or something but that wasn't true. Just slowly pull them apart, I used this guide to clean my pro controller, thanks!
AvariceHW - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 22
Son 7 gün: 67
Son 30 gün: 386
Her zaman: 29,312
