Ana içeriğe geç
System76 Serval WS Cooling Fan Replacement
Neye ihtiyacın var
  1. System76 Serval WS Cooling Fan Replacement, Cooling Fan: adım 1, 1 resimden 1.
    • Unplug the power supply and remove the battery from the device before proceeding.
    • Unscrew and remove the 4 screws circled in red. Then remove the plastic bottom panel.
  2. System76 Serval WS Cooling Fan Replacement: adım 2, 2 resimden 1. System76 Serval WS Cooling Fan Replacement: adım 2, 2 resimden 2.
    • Remove the numbered screws in order to safely remove the heatsink
    • Remove the heatsink to access the cooling fans.
    • During reassembly, make sure to tighten the heatsink screws in the order indicated by the labeled numbers.
  3. System76 Serval WS Cooling Fan Replacement: adım 3, 1 resimden 1.
    • Unscrew and remove the screws circled in red, 3 screws per fan.
    • Next unplug the 4-pin power connectors, marked in orange squares.
    • Remove the cooling fans by lifting them up and out of the casing.
  4. System76 Serval WS Cooling Fan Replacement: adım 4, 2 resimden 1. System76 Serval WS Cooling Fan Replacement: adım 4, 2 resimden 2.
    • Plug in the 4-pin power connectors of the new fans.
    • Insert and tighten 3 screws per fan.
    • If needed, clean off the old thermal paste from the CPU, GPU, and heatsink using isopropyl alcohol and a microfiber cloth. Apply new thermal paste before reassembly.
    • Clean the dust from the heatsink fins.
Sonuç
Oliver Anderson
289 İtibar
3 adet Kılavuz yazıldı
Ekip
1Rehber Yorum
What model of fan would one buy to replace this?
CrustyTrombone - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 13
Son 30 gün: 38
Her zaman: 853
