Ana içeriğe geç
TECHUP Bluetooth Speaker Motherboard Replacement
Neye ihtiyacın var
  1. TECHUP Bluetooth Speaker Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
    • Pry the foam buffer from the speaker using a nylon spudger or flathead screwdriver (pictured).
    • You will need to re-apply adhesive if you want to reattach this foam after removing it.
  2. TECHUP Bluetooth Speaker Motherboard Replacement: adım 2, 3 resimden 1. TECHUP Bluetooth Speaker Motherboard Replacement: adım 2, 3 resimden 2. TECHUP Bluetooth Speaker Motherboard Replacement: adım 2, 3 resimden 3.
    • Remove the two bottom screws using a Phillips #0 screwdriver.
  3. TECHUP Bluetooth Speaker Motherboard Replacement: adım 3, 2 resimden 1. TECHUP Bluetooth Speaker Motherboard Replacement: adım 3, 2 resimden 2.
    • Pull the plastic casing away from the speaker.
    • You may have to twist-and-pull to remove it.
  4. TECHUP Bluetooth Speaker Motherboard Replacement: adım 4, 2 resimden 1. TECHUP Bluetooth Speaker Motherboard Replacement: adım 4, 2 resimden 2.
    • Desolder the two battery wires from the motherboard.
    • Because you are dealing with battery connections, be aware of the shock hazard.
  5. TECHUP Bluetooth Speaker Motherboard Replacement: adım 5, 2 resimden 1. TECHUP Bluetooth Speaker Motherboard Replacement: adım 5, 2 resimden 2.
    • Desolder the two speaker wires from the motherboard.
  6. TECHUP Bluetooth Speaker Motherboard Replacement: adım 6, 1 resimden 1.
    • Grasp the motherboard and pull it from the encasement.
    • Take care to not rip the wires as you pull the motherboard out, as they may catch in the grooves on the motherboard.
  7. TECHUP Bluetooth Speaker Motherboard Replacement: adım 7, 1 resimden 1.
    • Pry the battery from the motherboard using a nylon spudger.
    • You may have to apply significant force to the motherboard to remove the battery.
    • Always use an ESD-safe tool, such as a nylon spudger, when working with batteries. Metal tools can puncture an unprotected battery, potentially causing a fire.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 19
Son 30 gün: 79
Her zaman: 2,639
