Ana içeriğe geç
TI-Nspire Battery Replacement
Neye ihtiyacın var
  1. TI-Nspire Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Face the side of the calculator with the "Texas Instruments" logo towards you, with the logo upright.
    • Slide the front cover down to remove it.
    FixBot'a Sor
    Yorum Ekle
  2. TI-Nspire Battery Replacement: adım 2, 2 resimden 1. TI-Nspire Battery Replacement: adım 2, 2 resimden 2.
    • The calculator should be facing front with the screen on the top and the keypad on the bottom.
    • Hold the long side of the calculator on the right or left and turn it 180 degrees so that the back of the calculator faces you.
    • Make sure that the current side facing you is the back by checking that the side has a "reset" button.
    FixBot'a Sor
    Yorum Ekle
  3. TI-Nspire Battery Replacement: adım 3, 1 resimden 1.
    • Locate the area with a switch on the bottom half of the calculator. Make the sure the switch is on the left side of the switch area, which indicates that it is locked.
    • Slide the switch until it moves from the left side of the button area all the way to the right side.
    • Make sure to hear a click once you move the switch all the way to the right, which indicates the keypad is now removable.
    FixBot'a Sor
    Yorum Ekle
  4. TI-Nspire Battery Replacement: adım 4, 1 resimden 1.
    • Turn the calculator back to the front as you would normally use it.
    FixBot'a Sor
    Yorum Ekle
  5. TI-Nspire Battery Replacement: adım 5, 2 resimden 1. TI-Nspire Battery Replacement: adım 5, 2 resimden 2.
    • Put your hand on the keypad, slide the keypad down about a half inch, and pull up to remove the keypad.
    FixBot'a Sor
    Yorum Ekle
  6. TI-Nspire Battery Replacement: adım 6, 1 resimden 1.
    • The batteries should be on the right and left side in the keypad area, with two on each side.
    • Place the tip of your finger in between the batteries, and remove the batteries. Repeat this for the other side as well.
    FixBot'a Sor
    Yorum Ekle
  7. TI-Nspire Battery Replacement: adım 7, 1 resimden 1.
    • When reassembling your device, use four new batteries.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. If your calculator doesn't turn on, it could be that the keypad isn't connected properly. If so, refer to Connecting the Keypad.
7 farklı kişi bu kılavuzu tamamladı.
Clincy Cheung
223 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 7-52, Forte Fall 2012 Cal Poly, Team 7-52, Forte Fall 2012 üyesi
CPSU-FORTE-F12S7G52
5 Üyeler
15 adet Kılavuz yazıldı
1Rehber Yorum
what should i do if it just stopped all of a sudden and my battery isn’t like that? Its a square not like A++
nenene kldbfssm - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 49
Her zaman: 18,088
