Ana içeriğe geç
TMY V08 Lens Replacement
Neye ihtiyacın var
    1. TMY V08 Lens Replacement, Top Panel: adım 1, 3 resimden 1. TMY V08 Lens Replacement, Top Panel: adım 1, 3 resimden 2. TMY V08 Lens Replacement, Top Panel: adım 1, 3 resimden 3.
      • Turn the projector upside-down.
      • Remove the six 10.8 mm screws from the bottom of the projector using a Phillips #1 screwdriver.
      • Turn the projector back over and lift the top casing panel off the projector.
      FixBot'a Sor
      Yorum Ekle
    2. TMY V08 Lens Replacement: adım 2, 3 resimden 1. TMY V08 Lens Replacement: adım 2, 3 resimden 2. TMY V08 Lens Replacement: adım 2, 3 resimden 3.
      • Pinch and pull the bundled cable connector from the top panel.
      • Remove the top panel from the projector.
      FixBot'a Sor
      Yorum Ekle
    1. TMY V08 Lens Replacement, Lens: adım 3, 3 resimden 1. TMY V08 Lens Replacement, Lens: adım 3, 3 resimden 2. TMY V08 Lens Replacement, Lens: adım 3, 3 resimden 3.
      • Remove the four 6.4 mm screws from the motherboard using a Phillips #1 screwdriver.
      • Pull back the motherboard to expose the connectors underneath.
      FixBot'a Sor
      Yorum Ekle
    2. TMY V08 Lens Replacement: adım 4, 2 resimden 1. TMY V08 Lens Replacement: adım 4, 2 resimden 2.
      • Rotate the projector counterclockwise 90 degrees.
      • Disconnect the three bundled cable connectors and the two power cable connectors from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. TMY V08 Lens Replacement: adım 5, 3 resimden 1. TMY V08 Lens Replacement: adım 5, 3 resimden 2. TMY V08 Lens Replacement: adım 5, 3 resimden 3.
      • Rotate the projector counter clockwise with the front facing you.
      • Remove the four 7.3 mm screws from the black cover to the left of the motherboard using a Phillips #1 screwdriver.
      • Remove the motherboard and black cover at the same time, being careful not to pull on the gold ribbon.
      FixBot'a Sor
      Yorum Ekle
    4. TMY V08 Lens Replacement: adım 6, 2 resimden 1. TMY V08 Lens Replacement: adım 6, 2 resimden 2.
      • Flip the projector over so the bottom is facing up.
      • Remove the two 13.9 mm screws using a Phillips #1 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    5. TMY V08 Lens Replacement: adım 7, 2 resimden 1. TMY V08 Lens Replacement: adım 7, 2 resimden 2.
      • Flip the projector back over.
      • Remove the fine gauge adjustment, by lifting it out.
      FixBot'a Sor
      Yorum Ekle
    6. TMY V08 Lens Replacement: adım 8, 3 resimden 1. TMY V08 Lens Replacement: adım 8, 3 resimden 2. TMY V08 Lens Replacement: adım 8, 3 resimden 3.
      • Grasp the side of the lens.
      • Pull the lens outward away from the hole while pulling upward to remove the lens.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Lesli
321 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 13
Son 30 gün: 69
Her zaman: 1,580
