Ana içeriğe geç
TMY V08 Lens Replacement
Neye ihtiyacın var
  1. TMY V08 Lens Replacement, Top Panel: adım 1, 3 resimden 1. TMY V08 Lens Replacement, Top Panel: adım 1, 3 resimden 2. TMY V08 Lens Replacement, Top Panel: adım 1, 3 resimden 3.
    • Turn the projector upside-down.
    • Remove the six 10.8 mm screws from the bottom of the projector using a Phillips #1 screwdriver.
    • Turn the projector back over and lift the top casing panel off the projector.
  2. TMY V08 Lens Replacement: adım 2, 3 resimden 1. TMY V08 Lens Replacement: adım 2, 3 resimden 2. TMY V08 Lens Replacement: adım 2, 3 resimden 3.
    • Pinch and pull the bundled cable connector from the top panel.
    • Remove the top panel from the projector.
  3. TMY V08 Lens Replacement, Lens: adım 3, 3 resimden 1. TMY V08 Lens Replacement, Lens: adım 3, 3 resimden 2. TMY V08 Lens Replacement, Lens: adım 3, 3 resimden 3.
    • Remove the four 6.4 mm screws from the motherboard using a Phillips #1 screwdriver.
    • Pull back the motherboard to expose the connectors underneath.
  4. TMY V08 Lens Replacement: adım 4, 2 resimden 1. TMY V08 Lens Replacement: adım 4, 2 resimden 2.
    • Rotate the projector counterclockwise 90 degrees.
    • Disconnect the three bundled cable connectors and the two power cable connectors from the motherboard.
  5. TMY V08 Lens Replacement: adım 5, 3 resimden 1. TMY V08 Lens Replacement: adım 5, 3 resimden 2. TMY V08 Lens Replacement: adım 5, 3 resimden 3.
    • Rotate the projector counter clockwise with the front facing you.
    • Remove the four 7.3 mm screws from the black cover to the left of the motherboard using a Phillips #1 screwdriver.
    • Remove the motherboard and black cover at the same time, being careful not to pull on the gold ribbon.
  6. TMY V08 Lens Replacement: adım 6, 2 resimden 1. TMY V08 Lens Replacement: adım 6, 2 resimden 2.
    • Flip the projector over so the bottom is facing up.
    • Remove the two 13.9 mm screws using a Phillips #1 screwdriver.
  7. TMY V08 Lens Replacement: adım 7, 2 resimden 1. TMY V08 Lens Replacement: adım 7, 2 resimden 2.
    • Flip the projector back over.
    • Remove the fine gauge adjustment, by lifting it out.
  8. TMY V08 Lens Replacement: adım 8, 3 resimden 1. TMY V08 Lens Replacement: adım 8, 3 resimden 2. TMY V08 Lens Replacement: adım 8, 3 resimden 3.
    • Grasp the side of the lens.
    • Pull the lens outward away from the hole while pulling upward to remove the lens.
Sonuç
Lesli
303 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 40
Her zaman: 195
