Giriş
This step-by-step guide teaches the users two procedures: removing and replacing an old lamp cord and attaching a new cord to the socket.
Neye ihtiyacın var
Required materials: AAMP rewire kit, light bulb (not pictured), lamp shade (optional).
The AAMP lamp rewire kit should include a new cord, a socket shell, a socket interior and bottle adaptors. (Refer the second image to view the contents of the kit).
Thread the new wire through the hole on the bottom of the lamp. Pull it out through the top of the lamp base. (Refer the first image to get a better understanding.)
Place the old check ring on top of the lamp with the wire threaded through it. (Refer the second image to see the check ring.)
Check both the conductors at the end of the wire. Find the ribbed conductor and wrap it around the silver-colored screw. Connect the other conductor to the brass-colored screw.
Tighten both of the screws in a clockwise direction. Make sure the conductors are securely under the screw head.
3 farklı kişi bu kılavuzu tamamladı.
