Ana içeriğe geç
Tagital T7X Battery Replacement
Neye ihtiyacın var
    1. Tagital T7X Battery Replacement, Case: adım 1, 3 resimden 1. Tagital T7X Battery Replacement, Case: adım 1, 3 resimden 2. Tagital T7X Battery Replacement, Case: adım 1, 3 resimden 3.
      • Place the Tagital T7X on a sturdy surface.
      • Insert the plastic opening tool into the crack and pry open the tablet. Move the tool along the edge, while continuing to pry up the casing.
      FixBot'a Sor
      Yorum Ekle
    1. Tagital T7X Battery Replacement, Battery: adım 2, 2 resimden 1. Tagital T7X Battery Replacement, Battery: adım 2, 2 resimden 2.
      • Follow the attached wires to the positive and negative connections.
      FixBot'a Sor
      Yorum Ekle
    2. Tagital T7X Battery Replacement: adım 3, 3 resimden 1. Tagital T7X Battery Replacement: adım 3, 3 resimden 2. Tagital T7X Battery Replacement: adım 3, 3 resimden 3.
      • The soldering iron can destroy components on the motherboard. Only touch the soldering iron to the solder already on the board.
      • Touch the tip of the soldering iron to the solder connecting the negative wire.
      • Pull back on the wire with the iron in place, removing it from the hot solder.
      • The solder will be melted almost instantly. There is no need to hold the iron on the solder for more than a second or two. Visit iFixit's soldering guide for more info.
      • Repeat this step for the positive wire.
      FixBot'a Sor
      Yorum Ekle
    3. Tagital T7X Battery Replacement: adım 4, 3 resimden 1. Tagital T7X Battery Replacement: adım 4, 3 resimden 2. Tagital T7X Battery Replacement: adım 4, 3 resimden 3.
      • Use the nylon spudger to pry the battery from the back of the screen. Work your way around the edges, similar to opening the casing.
      • The adhesive used to hold the battery down is very strong. Don't be afraid to use some force.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kevin Dennis
184 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 2-1, Sullivan Spring 2016 USF Tampa, Team 2-1, Sullivan Spring 2016 üyesi
USFT-SULLIVAN-S16S2G1
4 Üyeler
18 adet Kılavuz yazıldı
1Rehber Yorum
We're can I get a battery? And I don't think the part should have died in less than a year . The battery lasted less than 6 mos. I bought the tablet for my mom to play cards on and that's it .She doesn't go on line. I put a book on it before I gave it to her and that is it. She doesn't even use it every day . What's the deal?
Melanie Bouy - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 28
Her zaman: 1,400
