Ana içeriğe geç
Tagital T7X Speaker Replacement
Neye ihtiyacın var
  1. Tagital T7X Speaker Replacement, Case: adım 1, 3 resimden 1. Tagital T7X Speaker Replacement, Case: adım 1, 3 resimden 2. Tagital T7X Speaker Replacement, Case: adım 1, 3 resimden 3.
    • Place the Tagital T7X on a sturdy surface.
    • Insert the plastic opening tool into the crack and pry open the tablet. Move the tool along the edge, while continuing to pry up the casing.
  2. Tagital T7X Speaker Replacement, Speaker: adım 2, 3 resimden 1. Tagital T7X Speaker Replacement, Speaker: adım 2, 3 resimden 2. Tagital T7X Speaker Replacement, Speaker: adım 2, 3 resimden 3.
    • Remove the ribbon cable on the top left corner of the mother board.
    • Gently lift the black tape up to see the ribbon cable socket.
  3. Tagital T7X Speaker Replacement: adım 3, 3 resimden 1. Tagital T7X Speaker Replacement: adım 3, 3 resimden 2. Tagital T7X Speaker Replacement: adım 3, 3 resimden 3.
    • Push both side buttons away from the socket by using a spudger.
  4. Tagital T7X Speaker Replacement: adım 4, 2 resimden 1. Tagital T7X Speaker Replacement: adım 4, 2 resimden 2.
    • Gently pull the ribbon cable away from the socket.
    • Don't be afraid to use some force for this step.
  5. Tagital T7X Speaker Replacement: adım 5, 2 resimden 1. Tagital T7X Speaker Replacement: adım 5, 2 resimden 2.
    • The soldering iron can destroy components on the motherboard. Only touch the soldering iron to the solder already on the board.
    • Touch the tip of the soldering iron to the solder connecting the positive (red) wire.
    • Pull back on the wire with the iron in place, removing it from the hot solder.
    • Repeat this step for the negative wire.
    • The solder will be melted almost instantly. There is no need to hold the iron on the solder for than a second or two. Visit IFixit's soldering guide for more info.
  6. Tagital T7X Speaker Replacement: adım 6, 2 resimden 1. Tagital T7X Speaker Replacement: adım 6, 2 resimden 2.
    • Remove the speaker from the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Hanlong Chen
265 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-1, Sullivan Spring 2016 USF Tampa, Team 2-1, Sullivan Spring 2016 üyesi
USFT-SULLIVAN-S16S2G1
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 223
