Ana içeriğe geç
Tapwave T2907US Zodiac 2 Shoulder Button Replacement
Neye ihtiyacın var
  1. Tapwave T2907US Zodiac 2 Shoulder Button Replacement, Back Cover: adım 1, 1 resimden 1.
    • Remove the four Torx T5 screws from the back panel.
    FixBot'a Sor
    Yorum Ekle
  2. Tapwave T2907US Zodiac 2 Shoulder Button Replacement: adım 2, 1 resimden 1.
    • Wedge a spudger in between the front and back panel.
    • Apply leverage downwards to the spudger in order to remove the back panel.
    FixBot'a Sor
    Yorum Ekle
  3. Tapwave T2907US Zodiac 2 Shoulder Button Replacement, Battery: adım 3, 1 resimden 1.
    • Slide the battery out from under the brown wire-tape.
    • Be careful of the wires still connected to the other end of the battery. Do not pull or damage may occur.
    FixBot'a Sor
    Yorum Ekle
  4. Tapwave T2907US Zodiac 2 Shoulder Button Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Slowly pull the white plug from its receptor. Grasp its sides firmly with a pair of tweezers and gently wiggle from side to side.
    FixBot'a Sor
    Yorum Ekle
  5. Tapwave T2907US Zodiac 2 Shoulder Button Replacement, Motherboard: adım 5, 1 resimden 1.
    • Unscrew the 2 Philips #00 screws on each end of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  6. Tapwave T2907US Zodiac 2 Shoulder Button Replacement: adım 6, 1 resimden 1.
    • Pull off the black memory card slot piece with tweezers.
    FixBot'a Sor
    Yorum Ekle
  7. Tapwave T2907US Zodiac 2 Shoulder Button Replacement: adım 7, 1 resimden 1.
    • Unscrew the 2 Philips #00 screws on each side of the charging port.
    FixBot'a Sor
    Yorum Ekle
  8. Tapwave T2907US Zodiac 2 Shoulder Button Replacement: adım 8, 2 resimden 1. Tapwave T2907US Zodiac 2 Shoulder Button Replacement: adım 8, 2 resimden 2.
    • Disconnect 2 brown wire-tape ends from each end of the motherboard. Gently pull straight out with tweezers.
    FixBot'a Sor
    Yorum Ekle
  9. Tapwave T2907US Zodiac 2 Shoulder Button Replacement: adım 9, 1 resimden 1.
    • Pull the motherboard and screen component diagonally up and left away from the auxiliary port entrance to remove.
    • Glue connecting the auxiliary port to the casing may make it difficult to remove. Gently apply force as needed.
    FixBot'a Sor
    Yorum Ekle
  10. Tapwave T2907US Zodiac 2 Shoulder Button Replacement: adım 10, 1 resimden 1.
    • Disconnect the 2 brown wire-tape ends from the left side of the battery slot on the motherboard using tweezers.
    FixBot'a Sor
    Yorum Ekle
  11. Tapwave T2907US Zodiac 2 Shoulder Button Replacement: adım 11, 3 resimden 1. Tapwave T2907US Zodiac 2 Shoulder Button Replacement: adım 11, 3 resimden 2. Tapwave T2907US Zodiac 2 Shoulder Button Replacement: adım 11, 3 resimden 3.
    • Disconnect the large brown wire-tape from the motherboard.
    • Peel the black tape back from the wire-tape using tweezers.
    • Lift the black, hinged, plastic lock with tweezers to release the wire-tape.
    • The screen and motherboard components can now be separated from each other.
    FixBot'a Sor
    Yorum Ekle
  12. Tapwave T2907US Zodiac 2 Shoulder Button Replacement, Shoulder Button: adım 12, 1 resimden 1.
    Desoldering Pump
    $3.99
    • Carefully remove the solder between the shoulder buttons and the motherboard with the soldering sucker.
    • Try to avoid contact between the solder sucker and other components surrounding the shoulder buttons.
    • For more information on desoldering, look at this soldering/desoldering guide.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Daniel Wiseman
133 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-33, Amido Winter 2012 Cal Poly, Team 10-33, Amido Winter 2012 üyesi
CPSU-AMIDO-W12S10G33
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 28
Her zaman: 1,249
