Ana içeriğe geç
Technostar Sandwich Toaster Thermal Fuse Replacement
Neye ihtiyacın var
  1. Technostar Sandwich Toaster Thermal Fuse Replacement, Thermal Fuse: adım 1, 1 resimden 1.
    • Open the toaster.
    • Remove the four screws which attach the mold.
  2. Technostar Sandwich Toaster Thermal Fuse Replacement: adım 2, 2 resimden 1. Technostar Sandwich Toaster Thermal Fuse Replacement: adım 2, 2 resimden 2.
    • Remove the mold to get access to the heating coil.
  3. Technostar Sandwich Toaster Thermal Fuse Replacement: adım 3, 1 resimden 1.
    • Find the thermofuse.
  4. Technostar Sandwich Toaster Thermal Fuse Replacement: adım 4, 2 resimden 1. Technostar Sandwich Toaster Thermal Fuse Replacement: adım 4, 2 resimden 2.
    • Cut the two wires that connect to the thermal fuse.
  5. Technostar Sandwich Toaster Thermal Fuse Replacement: adım 5, 2 resimden 1. Technostar Sandwich Toaster Thermal Fuse Replacement: adım 5, 2 resimden 2.
    • Align the thermal fuse with the open wires.
    • Put the spade connectors over the wires.
    • Using pliers, clamp the wires together.
  6. Technostar Sandwich Toaster Thermal Fuse Replacement: adım 6, 1 resimden 1.
    • Replace the molds.
    • Replace the four screws which attach the mold.
Bitiş Çizgisi
4 farklı kişi bu kılavuzu tamamladı.
2 Yorum
where did u find the replacement fuse? I need a thermal fuse for Breville BSG520XL Panini Duo Grill
mortaz - Yanıt
how do i test that the reason that my toaster is not working is actually the thermal fuse?
itzsabag - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 42
Her zaman: 4,343
