Ana içeriğe geç
Teddy Ruxpin Mouth Replacement
Neye ihtiyacın var
  1. Teddy Ruxpin Mouth Replacement, Battery: adım 1, 2 resimden 1. Teddy Ruxpin Mouth Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the vest covering the back of the bear.
    • Orient the bear with his back facing upwards and unscrew the single Phillips #2 screw.
    • Captured screws will stay in place, no need to worry about losing this one!
  2. Teddy Ruxpin Mouth Replacement: adım 2, 1 resimden 1.
    • Pull the tab outward to remove the protective plate for the batteries.
  3. Teddy Ruxpin Mouth Replacement: adım 3, 1 resimden 1.
    • Remove all four AA batteries by pushing the positive end down and pulling the battery out toward yourself.
  4. Teddy Ruxpin Mouth Replacement, Arms: adım 4, 3 resimden 1. Teddy Ruxpin Mouth Replacement, Arms: adım 4, 3 resimden 2. Teddy Ruxpin Mouth Replacement, Arms: adım 4, 3 resimden 3.
    • Cut the orange shirt and zip tie.
    • Remove the zip tie.
  5. Teddy Ruxpin Mouth Replacement: adım 5, 1 resimden 1.
    • Cut across the back seam of the head of the bear along the arrow.
    • This damages the bear's exterior and will require resewing.
  6. Teddy Ruxpin Mouth Replacement: adım 6, 3 resimden 1. Teddy Ruxpin Mouth Replacement: adım 6, 3 resimden 2. Teddy Ruxpin Mouth Replacement: adım 6, 3 resimden 3.
    • Remove the interior of the doll.
    • Peel the outer layer around the head of the bear and forcefully pry off the face of the bear from the outside layer of the bear.
    • This will be difficult and require significant force, but do not fear about breaking the doll at this stage.
  7. Teddy Ruxpin Mouth Replacement: adım 7, 2 resimden 1. Teddy Ruxpin Mouth Replacement: adım 7, 2 resimden 2.
    • Extract each arm button.
    • Pull on the stuffing of the bear and not the wire to remove the arm button.
  8. Teddy Ruxpin Mouth Replacement: adım 8, 2 resimden 1. Teddy Ruxpin Mouth Replacement: adım 8, 2 resimden 2.
    • Pull off the rest of the outside layer of the bear.
  9. Teddy Ruxpin Mouth Replacement: adım 9, 1 resimden 1.
    • Unplug the arms from the main body.
  10. Teddy Ruxpin Mouth Replacement, Housing Cover: adım 10, 3 resimden 1. Teddy Ruxpin Mouth Replacement, Housing Cover: adım 10, 3 resimden 2. Teddy Ruxpin Mouth Replacement, Housing Cover: adım 10, 3 resimden 3.
    • Unscrew the eleven circled 12.5mm Phillips #1 screws.
    • Remove the top of the housing to access the electronics inside.
  11. Teddy Ruxpin Mouth Replacement, Eyes: adım 11, 1 resimden 1.
    • Using a Phillips #1 screwdriver, remove the two 12.5mm screws connecting the eyes to the rest of the mechanism.
  12. Teddy Ruxpin Mouth Replacement: adım 12, 2 resimden 1. Teddy Ruxpin Mouth Replacement: adım 12, 2 resimden 2.
    • Unplug the two sets of wires connected to the back of the eyes by using moderate to high force.
  13. Teddy Ruxpin Mouth Replacement: adım 13, 1 resimden 1.
    • Once those wires are disconnected, desolder the wires connected from the eye motherboard.
  14. Teddy Ruxpin Mouth Replacement, Mouth: adım 14, 2 resimden 1. Teddy Ruxpin Mouth Replacement, Mouth: adım 14, 2 resimden 2.
    • Remove five 12.5mm Phillips #1 screws.
    • Pull the mouth mechanism out of the shell.
  15. Teddy Ruxpin Mouth Replacement: adım 15, 2 resimden 1. Teddy Ruxpin Mouth Replacement: adım 15, 2 resimden 2.
    • Unscrew the last 12.5mm Phillips #1 screw holding the mouth together
    • Open the mouth mechanism
Sonuç
Jayin Patel
406 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G5, White Winter 2020 Cal Poly, Team S18-G5, White Winter 2020 üyesi
CPSU-WHITE-W20S18G5
4 Üyeler
7 adet Kılavuz yazıldı
3 Yorum
His mouth and nose fell out leaving a hole in his face. How do i fix it or is the repair shop local? He is 30 years old.
rrhall559 - Yanıt
Mouth and nose fellout
rrhall559 - Yanıt
World of wonder made it and they aren’t in business anymore
rrhall559 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 25
Her zaman: 1,426
