Ana içeriğe geç
Teddy Ruxpin Speaker Replacement
Neye ihtiyacın var
  1. Teddy Ruxpin Speaker Replacement, Battery: adım 1, 2 resimden 1. Teddy Ruxpin Speaker Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the vest covering the back of the bear.
    • Orient the bear with his back facing upwards and unscrew the single Phillips #2 screw.
    • Captured screws will stay in place, no need to worry about losing this one!
  2. Teddy Ruxpin Speaker Replacement: adım 2, 1 resimden 1.
    • Pull the tab outward to remove the protective plate for the batteries.
  3. Teddy Ruxpin Speaker Replacement: adım 3, 1 resimden 1.
    • Remove all four AA batteries by pushing the positive end down and pulling the battery out toward yourself.
  4. Teddy Ruxpin Speaker Replacement, Arms: adım 4, 3 resimden 1. Teddy Ruxpin Speaker Replacement, Arms: adım 4, 3 resimden 2. Teddy Ruxpin Speaker Replacement, Arms: adım 4, 3 resimden 3.
    • Cut the orange shirt and zip tie.
    • Remove the zip tie.
  5. Teddy Ruxpin Speaker Replacement: adım 5, 1 resimden 1.
    • Cut across the back seam of the head of the bear along the arrow.
    • This damages the bear's exterior and will require resewing.
  6. Teddy Ruxpin Speaker Replacement: adım 6, 3 resimden 1. Teddy Ruxpin Speaker Replacement: adım 6, 3 resimden 2. Teddy Ruxpin Speaker Replacement: adım 6, 3 resimden 3.
    • Remove the interior of the doll.
    • Peel the outer layer around the head of the bear and forcefully pry off the face of the bear from the outside layer of the bear.
    • This will be difficult and require significant force, but do not fear about breaking the doll at this stage.
  7. Teddy Ruxpin Speaker Replacement: adım 7, 2 resimden 1. Teddy Ruxpin Speaker Replacement: adım 7, 2 resimden 2.
    • Extract each arm button.
    • Pull on the stuffing of the bear and not the wire to remove the arm button.
  8. Teddy Ruxpin Speaker Replacement: adım 8, 2 resimden 1. Teddy Ruxpin Speaker Replacement: adım 8, 2 resimden 2.
    • Pull off the rest of the outside layer of the bear.
  9. Teddy Ruxpin Speaker Replacement: adım 9, 1 resimden 1.
    • Unplug the arms from the main body.
  10. Teddy Ruxpin Speaker Replacement, Housing Cover: adım 10, 3 resimden 1. Teddy Ruxpin Speaker Replacement, Housing Cover: adım 10, 3 resimden 2. Teddy Ruxpin Speaker Replacement, Housing Cover: adım 10, 3 resimden 3.
    • Unscrew the eleven circled 12.5mm Phillips #1 screws.
    • Remove the top of the housing to access the electronics inside.
  11. Teddy Ruxpin Speaker Replacement, Speaker: adım 11, 2 resimden 1. Teddy Ruxpin Speaker Replacement, Speaker: adım 11, 2 resimden 2.
    • Unscrew the two 12.5mm Phillips #1 screws holding the speaker cap on and remove the speaker cap.
  12. Teddy Ruxpin Speaker Replacement: adım 12, 1 resimden 1.
    • Desolder the wire from the speaker and replace.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jayin Patel
406 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G5, White Winter 2020 Cal Poly, Team S18-G5, White Winter 2020 üyesi
CPSU-WHITE-W20S18G5
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 743
