Ana içeriğe geç
Teenage Engineering OP-Z Battery Replacement
Neye ihtiyacın var
  1. Teenage Engineering OP-Z Battery Replacement, Back Cover: adım 1, 3 resimden 1. Teenage Engineering OP-Z Battery Replacement, Back Cover: adım 1, 3 resimden 2. Teenage Engineering OP-Z Battery Replacement, Back Cover: adım 1, 3 resimden 3.
    • Unlock the four rubber feet by turning them 90° counterclockwise using your thumb or finger tip.
    • There is a tiny mark on every foot facing the bottom edge of the OP-Z. After turning them they should face towards the short edge where the on/off switch is.
  2. Teenage Engineering OP-Z Battery Replacement: adım 2, 2 resimden 1. Teenage Engineering OP-Z Battery Replacement: adım 2, 2 resimden 2.
    • When turning the OP-Z over again the bottom plate should come off by itself (thanks gravity).
    • If the bottom plate won’t come off you might want to make sure every foot is rotated correctly and gently tug on one of them.
  3. Teenage Engineering OP-Z Battery Replacement: adım 3, 1 resimden 1.
    • Remove the bottom plate including the rubber feet.
  4. Teenage Engineering OP-Z Battery Replacement, Battery: adım 4, 2 resimden 1. Teenage Engineering OP-Z Battery Replacement, Battery: adım 4, 2 resimden 2.
    • Use your fingernail or a spudger to lift the battery on the right side where the notch is.
  5. Teenage Engineering OP-Z Battery Replacement: adım 5, 2 resimden 1. Teenage Engineering OP-Z Battery Replacement: adım 5, 2 resimden 2.
    • Remove the battery.
    • When installing the new battery make sure you put it in contact side first.
Sonuç
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Repair didn’t go as planned? Ask our Answers community for help.
4 farklı kişi bu kılavuzu tamamladı.
Tobias Isakeit
124.486 İtibar
189 adet Kılavuz yazıldı
Ekip
1Rehber Yorum
Does anyone know if there a way to purchase this battery in Australia? the link for the battery above says not available in Australia.. Does anyone know of another source? thanks
richard - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 35
Son 30 gün: 155
Her zaman: 8,611
