Ana içeriğe geç
Tennis Racquet Grip Tape Replacement
Aisleen Santos
Aisleen Santos ve 2 diğer katkıda bulunanlar
En son August 9, 2023 tarihinde güncellendi
5 - 10 dakika
Kolay
For this repair you will be removing your old grip and replacing it with a new Replacement Grip that you purchased from a sports store. This guide will also explain how to apply an Overgrip that you may have purchased for a variety of reasons: disliking the texture of the replacement grip, feeling you want a thicker grip, or simply wish to protect the more expensive Replacement Grip.
Neye ihtiyacın var
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. Tennis Racquet Grip Tape Replacement, Tennis Racket Grip Tape: adım 1, 2 resimden 1. Tennis Racquet Grip Tape Replacement, Tennis Racket Grip Tape: adım 1, 2 resimden 2.
    • Pull the rubber collar towards the tennis racquet head off the handle.
  2. Tennis Racquet Grip Tape Replacement: adım 2, 1 resimden 1.
    • Unwrap the tape on the tennis racquet handle top.
  3. Tennis Racquet Grip Tape Replacement: adım 3, 3 resimden 1. Tennis Racquet Grip Tape Replacement: adım 3, 3 resimden 2. Tennis Racquet Grip Tape Replacement: adım 3, 3 resimden 3.
    • Remove the old grip.
    • Some older tennis racquets may have a few staples holding the grip to the buttcap. Use the staple remover to take them out.
  4. Tennis Racquet Grip Tape Replacement: adım 4, 1 resimden 1.
    • Peel off 6 inches of the paper backing covering the adhesive from the replacement grip.
  5. Tennis Racquet Grip Tape Replacement: adım 5, 2 resimden 1. Tennis Racquet Grip Tape Replacement: adım 5, 2 resimden 2.
    • Face the racquet so the buttcap is towards you.
    • If you are left-handed, wrap the tape towards the right. This method is what is used in the photos.
    • If you are right-handed, wrap the tape towards the left
    • Wrap the grip flush with the buttcap base.
  6. Tennis Racquet Grip Tape Replacement: adım 6, 2 resimden 1. Tennis Racquet Grip Tape Replacement: adım 6, 2 resimden 2.
    • Wrap the handle at a steady incline, peeling off the backing 6 inches at a time.
    • Stop wrapping just before you finish wrapping the handle.
    • The handle is the off color or unpainted portion below the tennis racquet head.
  7. Tennis Racquet Grip Tape Replacement: adım 7, 2 resimden 1. Tennis Racquet Grip Tape Replacement: adım 7, 2 resimden 2.
    • Wrap the handle top with the backing on.
    • Mark a horizontal line parallel to the buttcap around the grip.
  8. Tennis Racquet Grip Tape Replacement: adım 8, 1 resimden 1.
    • Cut along the marked line using either scissors or a knife.
    • Cutting with scissors is significantly easier, however if you do not have scissors that can cut the grip, a knife will work.
  9. Tennis Racquet Grip Tape Replacement: adım 9, 1 resimden 1.
    • Remove the backing and finish wrapping the replacement grip.
  10. Tennis Racquet Grip Tape Replacement: adım 10, 1 resimden 1.
    • Wrap the tape that comes with the grip around the handle halfway on the racquet and halfway on the grip.
  11. Tennis Racquet Grip Tape Replacement: adım 11, 2 resimden 1. Tennis Racquet Grip Tape Replacement: adım 11, 2 resimden 2.
    • Complete your fix by pulling the rubber collar back to its original location.
    • If you do not wish to add an overgrip, skip step 12.
  12. Tennis Racquet Grip Tape Replacement: adım 12, 1 resimden 1.
    • Pull the collar up off the handle.
    • Repeat steps 4 - 11 to apply the overgrip.
Sonuç
Congratulations, your racquet grip is now fixed and you can go out and continue playing!
6 farklı kişi bu kılavuzu tamamladı.
Aisleen Santos
196 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team S3-G1, Coad Spring 2017 UC Davis, Team S3-G1, Coad Spring 2017 üyesi
UCD-COAD-S17S3G1
3 Üyeler
2 adet Kılavuz yazıldı
4 Yorum
Thank you I’ve found particularly useful the, then obvious when you think about it, comment that left handed setup is different to the right handed one!
Sam Curti - Yanıt
now this was helpfull, What's the difference between Eastern grip and Continental grip? Are they basically the same grip?
JACKSON RYAN - Yanıt
This guide about tennis grip was worth reading and helped to develop my skills to the next level.
Tennis Unit - Yanıt
I use this tennis guide, it’s quite worthy.
Rondaromero - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 20
Son 30 gün: 65
Her zaman: 19,052
