Ana içeriğe geç
Texas Instruments TI-30X IIS Solar Panel Replacement
Neye ihtiyacın var
  1. Texas Instruments TI-30X IIS Solar Panel Replacement, Solar Panel: adım 1, 2 resimden 1. Texas Instruments TI-30X IIS Solar Panel Replacement, Solar Panel: adım 1, 2 resimden 2.
    • Use a Phillips #000 screwdriver to remove the four 5 mm screws securing the back panel.
  2. Texas Instruments TI-30X IIS Solar Panel Replacement: adım 2, 1 resimden 1.
    • Wedge an opening tool in the gap between the front and back panel, then gently pry until the tabs release.
  3. Texas Instruments TI-30X IIS Solar Panel Replacement: adım 3, 1 resimden 1.
    • Use a Phillips #000 screwdriver to remove the two 3 mm screws securing the motherboard.
  4. Texas Instruments TI-30X IIS Solar Panel Replacement: adım 4, 1 resimden 1.
    • Desoldering and soldering presents a potential for device damage. Always solder/desolder in well-ventilated environments and with care not to burn yourself.
    • Desolder the positive the negative terminals on the motherboard.
  5. Texas Instruments TI-30X IIS Solar Panel Replacement: adım 5, 2 resimden 1. Texas Instruments TI-30X IIS Solar Panel Replacement: adım 5, 2 resimden 2.
    • Gently lift up the front of the motherboard, at the top of the calculator.
    • Desolder the positive and negative terminals on the solar panel
    • Use the tip of a spudger to "walk" the solar panel out of its housing, by pushing it down through the two cutouts until it slides out of the bottom.
    • Remove the solar panel.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 33
Her zaman: 864
