Ana içeriğe geç
The Claw Circuit Board Replacement
Neye ihtiyacın var
  1. The Claw Circuit Board Replacement, Bottom Cover: adım 1, 1 resimden 1.
    • Place The Claw in upright position with controls facing you.
    FixBot'a Sor
    Yorum Ekle
  2. The Claw Circuit Board Replacement: adım 2, 1 resimden 1.
    • Gently flip The Claw machine upside down with the controls facing you.
    FixBot'a Sor
    Yorum Ekle
  3. The Claw Circuit Board Replacement: adım 3, 1 resimden 1.
    • Remove all ten screws from the bottom cover using a Phillips #1 screwdriver.
    • You will need a screwdriver with a long thin neck to fit in the screw holes.
    FixBot'a Sor
    Yorum Ekle
  4. The Claw Circuit Board Replacement: adım 4, 2 resimden 1. The Claw Circuit Board Replacement: adım 4, 2 resimden 2.
    • Slide the bottom cover off to the side.
    • Do not completely remove bottom cover as it is still connected to wires.
    FixBot'a Sor
    Yorum Ekle
  5. The Claw Circuit Board Replacement: adım 5, 1 resimden 1.
    • Complete removal of the bottom cover is not necessary, however if you feel you need to take the cover completely off the machine to complete your task it can be done by the following process.
    • You will need to cut the two green wires attached to the music player.
    • Then you will need to cut the white wire that leads to the battery compartment.
    • Finally you will need to cut the black wire leading to the battery compartment as well.
    • The complete removal of the bottom cover requires the cutting and soldering of wires. For help with soldering reference: Lehimleme ve Lehim Sökme Bağlantıları Nasıl Yapılır.
    FixBot'a Sor
    Yorum Ekle
  6. The Claw Circuit Board Replacement, Circuit Board: adım 6, 1 resimden 1.
    • Once you have removed the bottom cover you should have clear access to the circuit board.
    • Locate the circuit board in the bottom of The Claw machine.
    FixBot'a Sor
    Yorum Ekle
  7. The Claw Circuit Board Replacement: adım 7, 1 resimden 1.
    • Locate the screws that hold the circuit board in place.
    FixBot'a Sor
    Yorum Ekle
  8. The Claw Circuit Board Replacement: adım 8, 1 resimden 1.
    • Be sure to turn off the device and remove the batteries before reaching into the device with your hands or any metal tools.
    • Using a Phillips #1 screwdriver, remove the four 6mm that hold the circuit board in place.
    • You will also need to cut all of the wires leading to the circuit board to completely remove it.
    FixBot'a Sor
    Yorum Ekle
  9. The Claw Circuit Board Replacement: adım 9, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Alain Pierre
1.188 İtibar
9 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-8, Catania Spring 2016 UMass Dartmouth, Team 4-8, Catania Spring 2016 üyesi
UMASSD-CATANIA-S16S4G8
3 Üyeler
18 adet Kılavuz yazıldı
9Kılavuz Yorumları
I accidentally cut the wires where the motors are and now can not figure out which go where, is there a diagram or drawling of where each wire goes?
Dyn4mic Universe - Yanıt Paylaş
Did you ever find a diagram for this? I would like to have one also….
Nathan Riffel - Yanıt Paylaş
Does anybody know where to get the replacement switches for these?
Bill B. - Yanıt Paylaş
Same. I am in need of the replacements as well.
Allison Rousseau - Yanıt Paylaş
Me too. L/R switch doesn't work need to replace it.
Johnny Annon - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 93
Her zaman: 7,805
