Ana içeriğe geç
The Claw Music Player Cleaning
Neye ihtiyacın var
    1. The Claw Music Player Cleaning, Bottom Cover: adım 1, 1 resimden 1.
      • Place The Claw in upright position with controls facing you.
      FixBot'a Sor
      Yorum Ekle
    2. The Claw Music Player Cleaning: adım 2, 1 resimden 1.
      • Gently flip The Claw machine upside down with the controls facing you.
      FixBot'a Sor
      Yorum Ekle
    3. The Claw Music Player Cleaning: adım 3, 1 resimden 1.
      • Remove all ten screws from the bottom cover using a Phillips #1 screwdriver.
      • You will need a screwdriver with a long thin neck to fit in the screw holes.
      FixBot'a Sor
      Yorum Ekle
    4. The Claw Music Player Cleaning: adım 4, 2 resimden 1. The Claw Music Player Cleaning: adım 4, 2 resimden 2.
      • Slide the bottom cover off to the side.
      • Do not completely remove bottom cover as it is still connected to wires.
      FixBot'a Sor
      Yorum Ekle
    5. The Claw Music Player Cleaning: adım 5, 1 resimden 1.
      • Complete removal of the bottom cover is not necessary, however if you feel you need to take the cover completely off the machine to complete your task it can be done by the following process.
      • You will need to cut the two green wires attached to the music player.
      • Then you will need to cut the white wire that leads to the battery compartment.
      • Finally you will need to cut the black wire leading to the battery compartment as well.
      • The complete removal of the bottom cover requires the cutting and soldering of wires. For help with soldering reference: Lehimleme ve Lehim Sökme Bağlantıları Nasıl Yapılır.
      FixBot'a Sor
      Yorum Ekle
    1. The Claw Music Player Cleaning, The Claw Music Player Cleaning: adım 6, 1 resimden 1.
      • Once you have removed the bottom cover you should have clear access to the music player.
      • Locate the music player and check to see if it is visibly dirty or clogged.
      • If there is any amount of dust or dirt on the music player it should be cleaned.
      • Using the straw that comes with your air duster, aim the duster in a way that the air will push the dust away from the music player.
      • If cleaning the music player is not enough, you may need to refer to the Music Player Replacement Guide
      FixBot'a Sor
      Yorum Ekle
    2. The Claw Music Player Cleaning: adım 7, 1 resimden 1.
      Bu adımda kullanılan alet:
      • You DO NOT want to force the dust further into the music player by directing the air into the player.
      • If there are any large pieces of lint or dust in the sound port, those can be removed with your precision tweezers.
      • Once you are certain you have removed all of the dust and dirt from the music player you should reassemble the device and test it.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alain Pierre
1.188 İtibar
9 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-8, Catania Spring 2016 UMass Dartmouth, Team 4-8, Catania Spring 2016 üyesi
UMASSD-CATANIA-S16S4G8
3 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 38
Her zaman: 1,170
