Ana içeriğe geç
The Sharper Image Literati Tablet SD Port Replacement
Neye ihtiyacın var
  1. The Sharper Image Literati Tablet SD Port Replacement, Battery: adım 1, 1 resimden 1.
    • Wedge plastic spudger tool between the back panel and the body of device.
    • Pry apart the back panel and the device.
  2. The Sharper Image Literati Tablet SD Port Replacement: adım 2, 1 resimden 1.
    • Desolder the battery wires from the circuit board.
  3. The Sharper Image Literati Tablet SD Port Replacement: adım 3, 1 resimden 1.
    • Warm the battery with a hair dryer.
    • Be carful not to over-heat the battery, this could cause the battery to ignite.
  4. The Sharper Image Literati Tablet SD Port Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    Plastic Cards
    $2.99
    • Gently wedge a spudger or thin plastic card between the battery and the body of device. Work the spudger or card along the length of the battery to free it from the adhesive.
    • Do not bend or puncture the battery. Work slowly and carefully.
  5. The Sharper Image Literati Tablet SD Port Replacement, SD Port: adım 5, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the fifteen 4mm screws from the silver peripheral edging.
  6. The Sharper Image Literati Tablet SD Port Replacement: adım 6, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove three 4 mm screws from the circuit board containing the headphone jack and power jack.
  7. The Sharper Image Literati Tablet SD Port Replacement: adım 7, 1 resimden 1.
    • Remove the circuit board.
  8. The Sharper Image Literati Tablet SD Port Replacement: adım 8, 1 resimden 1.
    • Unclip ZIF clip from the chip and unplug ribbon cable.
  9. The Sharper Image Literati Tablet SD Port Replacement: adım 9, 1 resimden 1.
    • Detach the peripheral edge with plastic wedge.
    • This may require a little hard pulling.
  10. The Sharper Image Literati Tablet SD Port Replacement: adım 10, 1 resimden 1.
    • Remove peripheral silver edge.
  11. The Sharper Image Literati Tablet SD Port Replacement: adım 11, 1 resimden 1.
    • Remove screws from the large metal shielding.
  12. The Sharper Image Literati Tablet SD Port Replacement: adım 12, 1 resimden 1.
    • Remove the silver backing plate and the adhered SD port chip.
Sonuç
Spencer Dodder
560 İtibar
4 adet Kılavuz yazıldı
Ekip
IUPUI, Team S5-G4, Baechle Spring 2018 IUPUI, Team S5-G4, Baechle Spring 2018 üyesi
IUPUI-BAECHLE-S18S5G4
3 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 342
