Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Wedge plastic spudger tool between the back panel and the body of device.
Pry apart the back panel and the device.
Bu adımda kullanılan alet:Plastic Cards$2.99-
Gently wedge a spudger or thin plastic card between the battery and the body of device. Work the spudger or card along the length of the battery to free it from the adhesive.
Use a Phillips #00 screwdriver to remove the fifteen 4mm screws from the silver peripheral edging.
Use a Phillips #00 screwdriver to remove three 4 mm screws from the circuit board containing the headphone jack and power jack.
Unclip ZIF clip from the chip and unplug ribbon cable.
Remove the silver backing plate and the adhered SD port chip.
