Ana içeriğe geç
ThinkPad T420 Keyboard Replacement
Neye ihtiyacın var
  1. Bu adımda kullanılan alet:
    Essential Electronics Toolkit
    $29.95
  2. ThinkPad T420 Keyboard Replacement, Keyboard FRU: adım 2, 1 resimden 1.
    • If the label on the back of the keyboard is not worn, that can be used to reference which keyboard is needed.
    • IMPORTANT: Each country has a different keyboard FRU part number. To match the keyboard you have and which one you need to purchase, check the back label or refer to the Lenovo HMM.
  3. ThinkPad T420 Keyboard Replacement, Unlock the battery: adım 3, 3 resimden 1. ThinkPad T420 Keyboard Replacement, Unlock the battery: adım 3, 3 resimden 2. ThinkPad T420 Keyboard Replacement, Unlock the battery: adım 3, 3 resimden 3.
    • If completing a step like a clone of your old hard drive/SSD, DO NOT remove the battery until the process is complete!
    • Unlock the latch locking the battery in the laptop.
    • NOTE: To remove the battery, the tab must be held in to avoid having the lock reinitiate inside the laptop.
  4. ThinkPad T420 Keyboard Replacement, Release the battery: adım 4, 3 resimden 1. ThinkPad T420 Keyboard Replacement, Release the battery: adım 4, 3 resimden 2. ThinkPad T420 Keyboard Replacement, Release the battery: adım 4, 3 resimden 3.
    • After unlocking the battery, remove the battery from the reverse way it is installed to remove it from the laptop.
  5. ThinkPad T420 Keyboard Replacement, Remove the RAM door: adım 5, 3 resimden 1. ThinkPad T420 Keyboard Replacement, Remove the RAM door: adım 5, 3 resimden 2. ThinkPad T420 Keyboard Replacement, Remove the RAM door: adım 5, 3 resimden 3.
    • EET owners: Your kit has this bit. No purchase needed.
    • If you are removing this cover to upgrade/replace your lower RAM module, the keyboard screw DOES NOT need to be removed.
    • WWAN ready systems ship with antenna covers over these cables. Someone installed a WLAN card in this T420 which disabled the better card and was removed.
    • Loosen the screw in red (Phillips #2). This screw stays captive in the bottom RAM door cover, and does not need to be removed.
    • Pull the cover up with a fingernail or a nonmarring pry tool.
    • Remove the screw retaining the keyboard.
  6. ThinkPad T420 Keyboard Replacement, Remove the keyboard: adım 6, 3 resimden 1. ThinkPad T420 Keyboard Replacement, Remove the keyboard: adım 6, 3 resimden 2. ThinkPad T420 Keyboard Replacement, Remove the keyboard: adım 6, 3 resimden 3.
    • Open the laptop.
    • To remove the keyboard, release the keyboard hooks using a plastic pry tool.
    • Once the keyboard is loose, remove it from the chassis.
  7. ThinkPad T420 Keyboard Replacement, Disconnect the keyboard: adım 7, 3 resimden 1. ThinkPad T420 Keyboard Replacement, Disconnect the keyboard: adım 7, 3 resimden 2. ThinkPad T420 Keyboard Replacement, Disconnect the keyboard: adım 7, 3 resimden 3.
    • To reinstall the keyboard, refer to the steps in this guide.
    • This step can be skipped if you remove the keyboard to upgrade/replace the RAM. However, disconnecting it may allow for better access to the upper (Keyboard) RAM module.
    • If you have a can of compressed air available, some of the dust can be removed at this point. Further disassembly is required for a full cleaning.
    • Disconnect the keyboard from the motherboard. Use a plastic pry tool for this step.
Bitiş Çizgisi
8 farklı kişi bu kılavuzu tamamladı.
Nick
98.896 İtibar
63 adet Kılavuz yazıldı
3Kılavuz Yorumları
Excellent guide, I like the detail specifying screw bits
Jakezxz1 - Yanıt
replacing the key went good but can’t get in because of password. need help
Steve Jacofsky - Yanıt
I love how simply disassemby are in those old ThinkPads <3
Ziobro - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 35
Son 30 gün: 144
Her zaman: 14,776
