Ana içeriğe geç
ThinkPad X1 Carbon Battery Replacement
Neye ihtiyacın var
  1. ThinkPad X1 Carbon Battery Replacement, Loosen Cover Screws: adım 1, 1 resimden 1.
    • Loosen the seven cover screws. They will not come out.
  2. ThinkPad X1 Carbon Battery Replacement, Remove Cover: adım 2, 1 resimden 1.
    • Use spudger to pop loose cover and slide off.
  3. ThinkPad X1 Carbon Battery Replacement, Disconnect Battery: adım 3, 1 resimden 1.
    • Only use plastic to remove battery connector
    • Gently remove battery connector by pushing with the spudger in the direction of the arrow.
    • Remove five screws holding battery in place and remove battery.
    Mine had a fifth screw (inside that circle in the center of the battery)
    Vinod Kurup - Yanıt
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Mike
1.906 İtibar
5 adet Kılavuz yazıldı
Ekip
iReconstruction iReconstruction üyesi
Business
1 Üye
16 adet Kılavuz yazıldı
3Kılavuz Yorumları
bonjour,
depuis que j’ai changé la batterie, elle ne charge plus… j’ai remis celle d’origine, idem…
Une idée?
merci d’avance.
Franck D'ALOIA - Yanıt
Bonjour,
J’ai le même phénomène que celui décrit plus haut par Franck D’ALOIA. La batterie de remplacement indique 100% de charge mais ne tient que 10min tout au plus.
Une idée ??
Merci à vous
Lamine Bouras - Yanıt
Minor correction to step #3 - the text says "remove 4 screws", but reality - and the photo - is that there are five screws.
Important: Note that the center one in the circular hole in the battery (under the trackpad) is a shorter length than the others.
davidhollway - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 58
Son 30 gün: 324
Her zaman: 22,448
