Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove the two 10mm black screws on the top of device using a Hex 2.5mm Key. Only the two outside screws.
Gently pull apart both halves of device to access inside.
Using a small plastic opening tool, gently pry up the white connector that connects the USB cable to the board.
Desolder the black cable that connects the USB port to the motherboard.
3 farklı kişi bu kılavuzu tamamladı.
7 Yorum
kunt u mij vertellen waar ik het kabeltje kan kopen?
Rene
Can you advise on where to obtain a new usb cable please? (clentonmalcolm@gmail.com)
Have you solved it? I'm worried it's different from the regular usb line.
sunned -
Then wat where do u get usb cord to replace it some one plz explian
Oh man.. the first comment about this was 2019 and we both are still waiting for an answer huh
