Ana içeriğe geç
Titan Airless Sprayer IMPACT 410 Capacitor Replacement
Neye ihtiyacın var
  1. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Safety precautions: adım 1, 2 resimden 1. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Safety precautions: adım 1, 2 resimden 2.
    • Before you begin, make sure to follow the pressure relief procedure documented in the user manual before powering down the paint sprayer and disconnecting the pump.
    • Turn off and unplug the sprayer.
  2. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Unfasten the motor cover: adım 2, 2 resimden 1. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Unfasten the motor cover: adım 2, 2 resimden 2.
    • Use a Phillips driver to remove the four 12 mm-long screws (two on either side) securing the motor cover.
  3. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the motor cover: adım 3, 3 resimden 1. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the motor cover: adım 3, 3 resimden 2. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the motor cover: adım 3, 3 resimden 3.
    • Pull the motor cover straight off the motor.
  4. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor wires: adım 4, 3 resimden 1. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor wires: adım 4, 3 resimden 2. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor wires: adım 4, 3 resimden 3.
    • Use diagonal cutters, or scissors, to cut the two cable ties bundling the capacitor's positive and negative wires.
    • During reassembly, replace the cable ties.
  5. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Disconnect the negative wire: adım 5, 2 resimden 1. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Disconnect the negative wire: adım 5, 2 resimden 2.
    • Disconnect the black negative wire's spade connector.
    • Always grip cables by their connectors and not the wires themselves.
  6. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Disconnect the positive wire: adım 6, 2 resimden 1. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Disconnect the positive wire: adım 6, 2 resimden 2.
    • Disconnect the red positive wire's bullet connector.
  7. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor: adım 7, 3 resimden 1. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor: adım 7, 3 resimden 2. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor: adım 7, 3 resimden 3.
    • Grip the cable tie and slide it off the capacitors.
  8. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Discharge the capacitors: adım 8, 1 resimden 1.
    • If you have already discharged the capacitors, skip this step.
    • Follow this guide to discharge your capacitors.
  9. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the capacitors: adım 9, 2 resimden 1. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the capacitors: adım 9, 2 resimden 2.
    • The capacitors are lightly adhered to the motor body.
    • Insert a flathead screwdriver underneath the capacitors, between the bottom cell and the adhesive.
    • Pry up to separate the bottom cell from the motor body.
  10. Titan Airless Sprayer IMPACT 410 Capacitor Replacement: adım 10, 3 resimden 1. Titan Airless Sprayer IMPACT 410 Capacitor Replacement: adım 10, 3 resimden 2. Titan Airless Sprayer IMPACT 410 Capacitor Replacement: adım 10, 3 resimden 3.
    • Insert a flathead screwdriver underneath the capacitors, between the top cell and the adhesive.
    • Pry up to separate the rest of the capacitor from the motor body.
    • Remove the capacitor.
    • During reassembly, if the adhesive is no longer sticky, replace it with double-sided foam adhesive.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alex Diaz-Kokaisl
163.918 İtibar
769 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
119 Üyeler
19.658 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 38
Her zaman: 446
