Ana içeriğe geç
Tivax MiTraveler 10Q-8 Battery Replacement
  1. Tivax MiTraveler 10Q-8 Battery Replacement, Rear Case: adım 1, 2 resimden 1. Tivax MiTraveler 10Q-8 Battery Replacement, Rear Case: adım 1, 2 resimden 2.
    • With the device face down, slide the charging port cover off on the left side of device.
  2. Tivax MiTraveler 10Q-8 Battery Replacement: adım 2, 1 resimden 1.
    • A phillips 2.88mm screw will be seen at the charging port.
  3. Tivax MiTraveler 10Q-8 Battery Replacement: adım 3, 1 resimden 1.
    • Use a PH000 Philips head screwdriver to remove screw.
    • Remember lefty loosey, righty tighty
  4. Tivax MiTraveler 10Q-8 Battery Replacement: adım 4, 1 resimden 1.
    • Use the plastic opening tool between the back plate and front plate to pry the back plate off; start at the headphone jack.
    • Make sure the lip of the plastic opening tool is face up.
  5. Tivax MiTraveler 10Q-8 Battery Replacement: adım 5, 2 resimden 1. Tivax MiTraveler 10Q-8 Battery Replacement: adım 5, 2 resimden 2.
    • Move around the device with the plastic opening tool pushing down to release the back plate from clips.
    • You will hear popping sounds when you work around the device.
  6. Tivax MiTraveler 10Q-8 Battery Replacement: adım 6, 2 resimden 1. Tivax MiTraveler 10Q-8 Battery Replacement: adım 6, 2 resimden 2.
    • Once you’ve moved around the whole device with the plastic opening tool, the back plate will completely release from the rest of the device.
  7. Tivax MiTraveler 10Q-8 Battery Replacement, Battery: adım 7, 1 resimden 1.
    • The battery rests flat on the inside surface of the tablet. It is a rectangular shape and has blue and yellow tape.
  8. Tivax MiTraveler 10Q-8 Battery Replacement: adım 8, 1 resimden 1.
    • There are two wires, one red and one black, that need to be desoldered from the motherboard that run to the battery.
    • Review how to solder here.
  9. Tivax MiTraveler 10Q-8 Battery Replacement: adım 9, 2 resimden 1. Tivax MiTraveler 10Q-8 Battery Replacement: adım 9, 2 resimden 2.
    • Work the soldering gun on the red wire where it is connected to the motherboard. it should release from the motherboard.
    • Work the soldering gun on the black wire where it is connected to the motherboard. It will release from the motherboard.
  10. Tivax MiTraveler 10Q-8 Battery Replacement: adım 10, 3 resimden 1. Tivax MiTraveler 10Q-8 Battery Replacement: adım 10, 3 resimden 2. Tivax MiTraveler 10Q-8 Battery Replacement: adım 10, 3 resimden 3.
    • Once both wires have been desoldered, the battery can be removed from the device.
Sonuç
Maria
210 İtibar
2 adet Kılavuz yazıldı
Colorado Springs, Team 4-3, Panko Spring 2015 Colorado Springs, Team 4-3, Panko Spring 2015 üyesi
UCCS-PANKO-S15S4G3
3 Üyeler
10 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 789
