Ana içeriğe geç
Toro 22-Inch Recycler Lawn Mower Blade Replacement
Mike Marshall
Mike Marshall ve başka bir katkıda bulunan
En son December 14, 2023 tarihinde güncellendi
10 dakika
Orta
Daha İyi Resimler Gerekli
Daha Fazla Görsel Gerekli
I'm about to show you how to change the blade on a Toro 22-inch Recycler lawnmower. It's a relatively simple process that should take only a few minutes. A socket wrench with a 5/8-inch bit, and a brick or a piece of wood are all that's required. Just make sure to drain the gas, put the lawnmower on its side, stabilize the blade, and unhook the sparkplug wire. It's important to unhook the sparkplug wire so the engine has no chance of starting. In only a few minutes, your Toro lawnmower will be producing a well-manicured lawn on a hot, sunny summer afternoon. Lawnmower users need to change the blade once every two years. You'll know when to change it when the blade looks dull or bent, and dents or gouges appear.
Neye ihtiyacın var
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. Toro 22-Inch Recycler Lawn Mower Blade Replacement, Blade: adım 1, 1 resimden 1.
    • Place the lawnmower on its side.
    • Drain the gas, and make sure the lawnmower is tilted so the oil dip stick is down.
    • Oil can't seep into the air filter if the oil dip stick is down. Draining the gas tank is important to prevent gas from being spilled.
  2. Toro 22-Inch Recycler Lawn Mower Blade Replacement: adım 2, 1 resimden 1.
    • Remove the sparkplug wire from the sparkplug.
    • This will prevent the lawnmower from starting during the repair.
  3. Toro 22-Inch Recycler Lawn Mower Blade Replacement: adım 3, 2 resimden 1. Toro 22-Inch Recycler Lawn Mower Blade Replacement: adım 3, 2 resimden 2.
    • Use a sturdy object, such as a brick or piece of wood, to keep the blade stable.
    • If using a brick or similar object, place it on the right side of the blade because we'll be turning the socket wrench to the left.
    • If using a piece of wood, place it across the bottom of the mower, so that the right side of the wood is wedged against the blade.
    • A small piece of wood is the most common way to stabilize the blade.
  4. Toro 22-Inch Recycler Lawn Mower Blade Replacement: adım 4, 1 resimden 1.
    • A socket wrench loosens the blade attachments. Attach a 5/8-inch bit to the socket wrench, and we're ready to loosen the nut.
  5. Toro 22-Inch Recycler Lawn Mower Blade Replacement: adım 5, 1 resimden 1.
    • Loosen the nut using a wrench with a 5/8-inch socket.
    • Consider wearing a pair of gloves for protection before using the wrench.
  6. Toro 22-Inch Recycler Lawn Mower Blade Replacement: adım 6, 1 resimden 1.
    • Remove the blade support and pull the blade.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 20
Son 30 gün: 52
Her zaman: 1,150
