Ana içeriğe geç
Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement
Sam Omiotek
Sam Omiotek
En son December 11, 2020 tarihinde güncellendi
30 dakika - 1 saat
Orta
  1. Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement, Turn off the power: adım 1, 2 resimden 1. Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement, Turn off the power: adım 1, 2 resimden 2.
    • Before you begin, ensure the machine is powered down and cool to the touch.
    • Turn the ignition switch to the off position.
  2. Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement, Close the fuel valve: adım 2, 2 resimden 1. Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement, Close the fuel valve: adım 2, 2 resimden 2.
    • Flip the fuel cutoff valve switch into the off position.
  3. Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement, Disconnect the spark plug: adım 3, 2 resimden 1. Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement, Disconnect the spark plug: adım 3, 2 resimden 2.
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  4. Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement, Tilt the cutter wheel up: adım 4, 1 resimden 1.
    • Tilt the machine so that it is resting on the handle with the cutter wheel raised.
  5. Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement, Remove the belt guard: adım 5, 2 resimden 1. Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement, Remove the belt guard: adım 5, 2 resimden 2.
    • Use a 14 mm socket to remove the fasteners securing the belt guard:
    • One 10 mm bolt
    • One 10 mm nut
  6. Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement: adım 6, 3 resimden 1. Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement: adım 6, 3 resimden 2. Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement: adım 6, 3 resimden 3.
    • Remove the belt guard.
  7. Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement, Remove the drive belt: adım 7, 3 resimden 1. Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement, Remove the drive belt: adım 7, 3 resimden 2. Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement, Remove the drive belt: adım 7, 3 resimden 3.
    • Use a 9/16 inch socket to loosen the four nuts securing the bottom of the motor enough to allow the motor to slide freely. Do not remove the nuts.
    • Use a 1/2 inch wrench in combination with the socket wrench to hold the bolts in place.
  8. Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement: adım 8, 1 resimden 1.
    • Use a 1/2 inch wrench to loosen the two bolts behind the centrifugal clutch enough to allow the motor to slide freely. Do not remove the bolts.
  9. Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement: adım 9, 2 resimden 1. Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement: adım 9, 2 resimden 2.
    • Wrap a piece of tape around the upper half of the tensioner bolt to mark the location of the second nut.
    • Use a 9/16 inch wrench to loosen the nut on the lower half of the tensioner bolt until the motor can slide forward as much as possible.
    • During reassembly, reference the tape to position the outer nut into the same location as before to ensure proper belt tension.
  10. Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement: adım 10, 2 resimden 1. Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement: adım 10, 2 resimden 2.
    • Slide the engine towards the cutter blade to loosen the drive belt.
  11. Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement: adım 11, 3 resimden 1. Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement: adım 11, 3 resimden 2. Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement: adım 11, 3 resimden 3.
    • Lift the drive belt up and away from the machine while rolling it towards the cutter head to gradually roll it off of the pulley.
  12. Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement: adım 12, 1 resimden 1.
    • Remove the drive belt.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Sam Omiotek
84.357 İtibar
290 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 43
Her zaman: 1,956
