Giriş
This guide shows how to remove and replace the brake cable on the Toro Walk Behind Mower 21199HD 2018.
Neye ihtiyacın var
Grab the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
Chock the rear wheels to prevent the mower from rolling during service.
While holding the deflector up and out of the way, lift the grass bag handle away from the mower to detach it.
Remove the grass bag.
Cut and remove the zip tie holding the cables together near the base of the handle.
Use your fingers and press up from the bottom to remove the plastic cable guide from the handle.
Rotate the cable retainer arm 90˚ upwards, perpendicular to the handle, to unlock it.
Pull the arm away from the handle to remove it.
Use a flathead screwdriver to pry off the single-use cap locking the brake cable to the brake handle.
Use a 3/8 inch socket to remove the cable guide plate screw.
Tilt the mower onto its side, propping the handle up with a block of wood.
Locate the end of the brake cable underneath the mower, in front of the driveline, and above the blade guard.
Reach into the underside of the mower and grab the spring at the end of the brake cable.
Slide the spring towards the open end of the U-shaped post.
3 farklı kişi bu kılavuzu tamamladı.
