Ana içeriğe geç
Torque King Electric RTR RC Monster Truck Motor Replacement
Neye ihtiyacın var
  1. Torque King Electric RTR RC Monster Truck Motor Replacement, Casing: adım 1, 2 resimden 1. Torque King Electric RTR RC Monster Truck Motor Replacement, Casing: adım 1, 2 resimden 2.
    • From the top view, remove each of the four pins that hold the casing in place.
  2. Torque King Electric RTR RC Monster Truck Motor Replacement: adım 2, 1 resimden 1.
    • Slowly pull the casing up to remove it.
  3. Torque King Electric RTR RC Monster Truck Motor Replacement, Battery: adım 3, 1 resimden 1.
    • Beginning at the bottom of the truck, twist the release clip on the casing until the release clip is no longer covering the battery casing.
  4. Torque King Electric RTR RC Monster Truck Motor Replacement: adım 4, 1 resimden 1.
    • Next, use a Phillips 00 screwdriver to remove the 8mm screw on the battery casing and remove the battery casing.
  5. Torque King Electric RTR RC Monster Truck Motor Replacement: adım 5, 1 resimden 1.
    • Do not skip this step if you are continuing onto the next step, you will risk electric shock.
    • Finally, remove the battery from the white connector by squeezing the clip on the connector while pulling.
  6. Torque King Electric RTR RC Monster Truck Motor Replacement, Removing Screws: adım 6, 1 resimden 1.
    • Using a Phillips 1 screwdriver, completely unscrew the 8mm screw located in the center of the wheel. Repeat this step for other wheels if needed.
  7. Torque King Electric RTR RC Monster Truck Motor Replacement, Removing the Wheel: adım 7, 1 resimden 1.
    • Carefully pull the wheel off of its axle. Repeat for other wheels as necessary.
  8. Torque King Electric RTR RC Monster Truck Motor Replacement, Motor: adım 8, 2 resimden 1. Torque King Electric RTR RC Monster Truck Motor Replacement, Motor: adım 8, 2 resimden 2.
    • After removing the rear wheels, use a Phillips #1 screwdriver to remove the two 11m screws indicated.
  9. Torque King Electric RTR RC Monster Truck Motor Replacement: adım 9, 1 resimden 1.
    • Remove the cap to reveal the motor.
  10. Torque King Electric RTR RC Monster Truck Motor Replacement: adım 10, 2 resimden 1. Torque King Electric RTR RC Monster Truck Motor Replacement: adım 10, 2 resimden 2.
    • Remove the metal piece that clasps the motor in place.
  11. Torque King Electric RTR RC Monster Truck Motor Replacement: adım 11, 1 resimden 1.
    • Carefully pull out the motor from the chassis.
  12. Torque King Electric RTR RC Monster Truck Motor Replacement: adım 12, 1 resimden 1.
    • Warning: Ensure that the battery is properly removed before attempting this step. If you attempt this step with the battery in you risk injury by electric shock and damage to the truck.
    • Desolder the red and black wires from the motor. Note where each wire is supposed to connect.
    • Caution: Do not desolder the small orange capacitor.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Maximiliano Cortes
418 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-30, Amido Winter 2015 Cal Poly, Team 6-30, Amido Winter 2015 üyesi
CPSU-AMIDO-W15S6G30
4 Üyeler
16 adet Kılavuz yazıldı
Bir Yorum
My favorite trucks were Chalkboard Chuck and Samson, but I took pictures of several of the trucks and tried repeatedly to snap the perfect picture. {Obviously my perfect pics are a bit fuzzy.}
In addition to the big-honking Monster Trucks we also got to see some daring and dangerous motorcycle stunts!
https://babyishcare.com/radio-control-mo...
Beth Bishop - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 464
