Ana içeriğe geç
Toshiba Chromebook 2 Motherboard Replacement
Neye ihtiyacın var
  1. Toshiba Chromebook 2 Motherboard Replacement, Back Cover: adım 1, 1 resimden 1.
    • Remove all external devices from the Toshiba Chromebook 2.
  2. Toshiba Chromebook 2 Motherboard Replacement: adım 2, 1 resimden 1.
    • Close the Toshiba Chromebook 2 and turn it over so that the bottom of the laptop is facing upwards toward you with the lettering on the bottom facing right side up.
  3. Toshiba Chromebook 2 Motherboard Replacement: adım 3, 2 resimden 1. Toshiba Chromebook 2 Motherboard Replacement: adım 3, 2 resimden 2.
    • Remove the 8 visible Phillips 8.25 mm screws using the Phillips #0 screwdriver.
  4. Toshiba Chromebook 2 Motherboard Replacement: adım 4, 2 resimden 1. Toshiba Chromebook 2 Motherboard Replacement: adım 4, 2 resimden 2.
    • Remove 2 hidden Phillips 8.25 mm screws located underneath the rubber grips at the back (opposite the hinges) with the Phillips #0 screwdriver.
    • The rubber grips are glued in place, so you'll need to peel them up with a spudger or other pry tool.
  5. Toshiba Chromebook 2 Motherboard Replacement: adım 5, 1 resimden 1.
    • Remove the back panel by pulling up on 2 adjacent corners.
  6. Toshiba Chromebook 2 Motherboard Replacement, Motherboard: adım 6, 2 resimden 1. Toshiba Chromebook 2 Motherboard Replacement, Motherboard: adım 6, 2 resimden 2.
    • Remove the 14 Phillips 2.34mm screws using the Phillips #0 screwdriver.
  7. Toshiba Chromebook 2 Motherboard Replacement: adım 7, 1 resimden 1.
    • Remove the metal plate covering the motherboard by lifting it vertically.
  8. Toshiba Chromebook 2 Motherboard Replacement: adım 8, 3 resimden 1. Toshiba Chromebook 2 Motherboard Replacement: adım 8, 3 resimden 2. Toshiba Chromebook 2 Motherboard Replacement: adım 8, 3 resimden 3.
    • Flip up the plastic clamps holding down the 4 ribbon cables connected to the motherboard while gently pulling the ribbon cables from the sockets.
  9. Toshiba Chromebook 2 Motherboard Replacement: adım 9, 3 resimden 1. Toshiba Chromebook 2 Motherboard Replacement: adım 9, 3 resimden 2. Toshiba Chromebook 2 Motherboard Replacement: adım 9, 3 resimden 3.
    • Use the spudger to press down on the 2 white port cables, while also pulling each white port cable out of their sockets.
  10. Toshiba Chromebook 2 Motherboard Replacement: adım 10, 3 resimden 1. Toshiba Chromebook 2 Motherboard Replacement: adım 10, 3 resimden 2. Toshiba Chromebook 2 Motherboard Replacement: adım 10, 3 resimden 3.
    • Disconnect the motherboard from the 3 remaining cables by pulling the chords out of the sockets.
  11. Toshiba Chromebook 2 Motherboard Replacement: adım 11, 2 resimden 1. Toshiba Chromebook 2 Motherboard Replacement: adım 11, 2 resimden 2.
    • Remove the motherboard by pulling upward and to the right.
    • Be careful not to damage the ports located on the left side of the motherboard during removal.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Sam Nishi
485 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 10-4, Livingston Fall 2016 Cal Poly, Team 10-4, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S10G4
4 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 2,907
