Ana içeriğe geç
Toshiba Portege Z835-P330 Internal Cooling Fan Replacement
Neye ihtiyacın var
  1. Toshiba Portege Z835-P330 Internal Cooling Fan Replacement, Internal Cooling Fan: adım 1, 1 resimden 1.
    • Remove the thirteen 1.4mm screws using a Phillips #2 screwdriver.
  2. Toshiba Portege Z835-P330 Internal Cooling Fan Replacement: adım 2, 1 resimden 1.
    • Locate hidden screw found in the middle of back hardcover.
    • Here you will find a proprietary Japanese Screw Head.
    • Remove screw by using tool not provided by IFixit or by using the methods found here.
  3. Toshiba Portege Z835-P330 Internal Cooling Fan Replacement: adım 3, 1 resimden 1.
    • Peel off hard cover to expose interior of device
  4. Toshiba Portege Z835-P330 Internal Cooling Fan Replacement: adım 4, 1 resimden 1.
    • Remove the two 1 mm screws using a Phillips #2 screwdriver.
  5. Toshiba Portege Z835-P330 Internal Cooling Fan Replacement: adım 5, 1 resimden 1.
    • Unplug the internal cooling fan by tugging gently on the wire attatched to the device's motherboard
  6. Toshiba Portege Z835-P330 Internal Cooling Fan Replacement: adım 6, 1 resimden 1.
    • Lift the internal cooling fan to remove the fan from the device
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 585
