Ana içeriğe geç
Toshiba Satellite 1805-S177 Keyboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite 1805-S177 Keyboard Replacement, Keyboard: adım 1, 2 resimden 1. Toshiba Satellite 1805-S177 Keyboard Replacement, Keyboard: adım 1, 2 resimden 2.
    • Stick a spudger in one of the sides of the top panel. Lift slowly from one side to the other and it will pop off.
  2. Toshiba Satellite 1805-S177 Keyboard Replacement: adım 2, 3 resimden 1. Toshiba Satellite 1805-S177 Keyboard Replacement: adım 2, 3 resimden 2. Toshiba Satellite 1805-S177 Keyboard Replacement: adım 2, 3 resimden 3.
    • Using an Phillips screwdriver, unscrew and remove two screws labeled B2.6.
  3. Toshiba Satellite 1805-S177 Keyboard Replacement: adım 3, 1 resimden 1.
    • Using your hands, lift keyboard up toward you, starting from the edge closest to the screen.
    • The keyboard is still connected to the laptop by a ribbon. Place the keyboard gently on top of the trackpad, keys side down.
  4. Toshiba Satellite 1805-S177 Keyboard Replacement: adım 4, 2 resimden 1. Toshiba Satellite 1805-S177 Keyboard Replacement: adım 4, 2 resimden 2.
    • Find the white ribbon connector (where the keyboard is still attached to the rest of the laptop).
    • Slide the white ribbon connector up and lift the ribbon out of it.
Sonuç
Hannah
251 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-5, Johann Summer 2010 Cal Poly, Team 3-5, Johann Summer 2010 üyesi
CPSU-JOHANN-R10S3G5
4 Üyeler
24 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 15
Son 30 gün: 71
Her zaman: 3,028
