Ana içeriğe geç
Toshiba Satellite A210 Keyboard Replacement
Youlen
Youlen ve 12 diğer katkıda bulunanlar
En son January 21, 2025 tarihinde güncellendi
5 - 10 dakika
Orta
Hatalı İşaretlenmiş
Daha Fazla Görsel Gerekli
In this guide you will learn how to remove a keyboard safely. Before you begin this guide you should have all required materials and tools necessary to properly remove the keyboard.
Neye ihtiyacın var
Aletler
  1. Toshiba Satellite A210 Keyboard Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite A210 Keyboard Replacement, Battery: adım 1, 2 resimden 2.
    • Unplug the AC adapter and all other auxiliary components from the laptop.
    • Slide the battery lock tab away from the center of the laptop to unlock the battery.
  2. Toshiba Satellite A210 Keyboard Replacement: adım 2, 2 resimden 1. Toshiba Satellite A210 Keyboard Replacement: adım 2, 2 resimden 2.
    • Slide the battery release tab away from the center of the laptop and hold it.
    • Lifting from the small notch between the two tabs, pull the battery out of the laptop.
  3. Toshiba Satellite A210 Keyboard Replacement, Keyboard: adım 3, 1 resimden 1.
    • Unscrew the 4 highlighted screws with a PH1 screwdriver.
  4. Toshiba Satellite A210 Keyboard Replacement: adım 4, 3 resimden 1. Toshiba Satellite A210 Keyboard Replacement: adım 4, 3 resimden 2. Toshiba Satellite A210 Keyboard Replacement: adım 4, 3 resimden 3.
    • Orient the laptop so that the screen is open and facing you.
    • Slide the plastic opening tool underneath the top edge of the black plastic insert.
    • Pull it off and set aside.
  5. Toshiba Satellite A210 Keyboard Replacement: adım 5, 2 resimden 1. Toshiba Satellite A210 Keyboard Replacement: adım 5, 2 resimden 2.
    • Remove the 2 PH1 screws.
    • Lift the keyboard from the top being carful not to remove it fully. There is still a ribbon cable that connects the keyboard to the laptop.
  6. Toshiba Satellite A210 Keyboard Replacement: adım 6, 1 resimden 1.
    • Disconnect the keyboard ribbon cable and remove the keyboard from the laptop.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Youlen
49 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-5, Regan Spring 2013 Cal Poly, Team 17-5, Regan Spring 2013 üyesi
CPSU-REGAN-S13S17G5
4 Üyeler
18 adet Kılavuz yazıldı
Bir Yorum
very useful. THANKS
ANDREAS - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 20
Her zaman: 2,677
