Ana içeriğe geç
Toshiba Satellite A210 Optical Disc Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite A210 Optical Disc Drive Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite A210 Optical Disc Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Unplug the AC adapter and all other auxiliary components from the laptop.
    • Slide the battery lock tab away from the center of the laptop to unlock the battery.
  2. Toshiba Satellite A210 Optical Disc Drive Replacement: adım 2, 2 resimden 1. Toshiba Satellite A210 Optical Disc Drive Replacement: adım 2, 2 resimden 2.
    • Slide the battery release tab away from the center of the laptop and hold it.
    • Lifting from the small notch between the two tabs, pull the battery out of the laptop.
  3. Toshiba Satellite A210 Optical Disc Drive Replacement, RAM: adım 3, 2 resimden 1. Toshiba Satellite A210 Optical Disc Drive Replacement, RAM: adım 3, 2 resimden 2.
    • Remove the screw holding the RAM cover with a PH1 screwdriver.
    • Remove the RAM cover.
  4. Toshiba Satellite A210 Optical Disc Drive Replacement: adım 4, 3 resimden 1. Toshiba Satellite A210 Optical Disc Drive Replacement: adım 4, 3 resimden 2. Toshiba Satellite A210 Optical Disc Drive Replacement: adım 4, 3 resimden 3.
    • Push outwards on the metal tabs to release the RAM.
    • Remove the RAM. Some force may be needed.
    • Be careful not to touch the gold pins on the RAM chips as there may be a build-up of static electricity. This can fry the parts of the chip that houses memory.
  5. Toshiba Satellite A210 Optical Disc Drive Replacement, Optical Disc Drive: adım 5, 3 resimden 1. Toshiba Satellite A210 Optical Disc Drive Replacement, Optical Disc Drive: adım 5, 3 resimden 2. Toshiba Satellite A210 Optical Disc Drive Replacement, Optical Disc Drive: adım 5, 3 resimden 3.
    • Use a PH0 screwdriver to remove the screw holding the optical drive in place.
    • Using your index finger, push the metal tab inside the RAM bay which is located directly underneath the screw-hole.
    • The optical drive will then slide out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bret Wilson
289 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 17-5, Regan Spring 2013 Cal Poly, Team 17-5, Regan Spring 2013 üyesi
CPSU-REGAN-S13S17G5
4 Üyeler
18 adet Kılavuz yazıldı
1Rehber Yorum
Question : if i this will my screen start working ng again
jessica johnson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 18
Her zaman: 1,700
