Neye ihtiyacın var
Turn off the computer.
Disconnect the charging cable from computer.
Flip the computer upside down.
Bu adımda kullanılan alet:Anti-Static Wrist Strap$7.95
Locate 2 metal pinchers on either side of the 1st RAM stick.
Use a finger from each hand to push the 2 pinchers simultaneously away from the stick of RAM and towards the exterior of the case.
The RAM stick will automatically rise up. Gently pull out the RAM stick with one hand.
Bu adımda kullanılan alet:Tweezers$4.99
Locate and remove 1 Phillips 4.2 mm size screw along right side of RAM container.
