Toshiba Satellite A75-S226 Heat Sink Replacement
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
Remove the 5.64 mm screw from the bottom of the crossing bar.
Remove the crossing bar.
Use the plastic opening tool to lift up the top panel all the way along the keyboard until it loosens.
Use the Phillips screwdriver to remove the two 3.7 mm screws from the battery compartment.
Then remove the fourteen 8.6 mm screws from the bottom of the case.
Using the Phillips Screwdriver, remove the two 8.6 mm screws from the front edge of the motherboard.
With the Phillips screwdriver, remove the four screws holding the heatsink on the motherboard.
2 farklı kişi bu kılavuzu tamamladı.
