Ana içeriğe geç
Toshiba Satellite C55-A5140 Headphone jack Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C55-A5140 Headphone jack Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the device is unplugged, completely off, and not warm to the touch.
    • Check for any visible battery defects such as bulges, bends or cracking as they could be signs of a leaking or deformed battery.
    • Do not handle a deformed battery. Deformed batteries can cause burns and exposure to harmful chemicals.
    • Flip device over and locate two switches on the back of the device.
  2. Toshiba Satellite C55-A5140 Headphone jack Replacement: adım 2, 2 resimden 1. Toshiba Satellite C55-A5140 Headphone jack Replacement: adım 2, 2 resimden 2.
    • Slide switch 1 towards the unlock symbol on the device (switch should click into place).
    • Slide switch 2 towards the unlocked symbol on the device.
    • While holding switch 2 in the unlocked position, use the notch located at the top of the battery to pull battery out and away from the device.
    • Switch 2 does not lock into place and will need to be held in unlocked position.
  3. Toshiba Satellite C55-A5140 Headphone jack Replacement: adım 3, 1 resimden 1.
    • Pull battery free from device and release switch 2.
  4. Toshiba Satellite C55-A5140 Headphone jack Replacement, CD Drive: adım 4, 1 resimden 1.
    • Make sure that the device is unplugged, completely off, and that the device is not warm to the touch.
    • Flip the device over so you see the bottom, and loosen the 5mm PH#1 screw on the L shaped access panel.
    • The screw will not come out of access panel, simply unscrew until loose.
  5. Toshiba Satellite C55-A5140 Headphone jack Replacement: adım 5, 1 resimden 1.
    • Use the plastic opening tool to open access panel by sliding it into notch near screw and prying access panel(L-shaped) away from device.
    • Pull panel completely free from device and set aside.
  6. Toshiba Satellite C55-A5140 Headphone jack Replacement: adım 6, 1 resimden 1.
    • Unscrew the 2mm PH#1 screw next to the Toshiba Device information tag.
  7. Toshiba Satellite C55-A5140 Headphone jack Replacement: adım 7, 3 resimden 1. Toshiba Satellite C55-A5140 Headphone jack Replacement: adım 7, 3 resimden 2. Toshiba Satellite C55-A5140 Headphone jack Replacement: adım 7, 3 resimden 3.
    • Using the plastic opening tool, pry the CD drive up.
    • Once the CD drive is partially separated from the device, grasp with your hand and slide it out of the slot.
  8. Toshiba Satellite C55-A5140 Headphone jack Replacement, Headphone jack: adım 8, 1 resimden 1.
    • Unscrew the twelve 5mm PH#1 screws on the bottom of the device.
  9. Toshiba Satellite C55-A5140 Headphone jack Replacement: adım 9, 2 resimden 1. Toshiba Satellite C55-A5140 Headphone jack Replacement: adım 9, 2 resimden 2.
    • Remove the 4mm PH#1 screw on aluminum tray cover inside of access panel.
    • Pull aluminum cover away from device and put aside.
  10. Toshiba Satellite C55-A5140 Headphone jack Replacement: adım 10, 1 resimden 1.
    • Remove the remaining five 10mm PH#1 screws within access panel.
  11. Toshiba Satellite C55-A5140 Headphone jack Replacement: adım 11, 3 resimden 1. Toshiba Satellite C55-A5140 Headphone jack Replacement: adım 11, 3 resimden 2. Toshiba Satellite C55-A5140 Headphone jack Replacement: adım 11, 3 resimden 3.
    • Using a metal spudger, remove the back cover by working metal spudger around edges of the laptop. Pry base away from rest of device until separated.
    • Separate back cover completely from device and set aside.
    • Plastic joints will make a snapping sound as they are released.
  12. Toshiba Satellite C55-A5140 Headphone jack Replacement: adım 12, 2 resimden 1. Toshiba Satellite C55-A5140 Headphone jack Replacement: adım 12, 2 resimden 2.
    • Loosen the four 5mm PH#1 screws on heat sink.
    • Pull heat sink out and away from motherboard and set aside.
    • Screws on heat sink will not come out completely. Simply unscrew until lose.
  13. Toshiba Satellite C55-A5140 Headphone jack Replacement: adım 13, 2 resimden 1. Toshiba Satellite C55-A5140 Headphone jack Replacement: adım 13, 2 resimden 2.
    • Gently unplug 5 connections on top of motherboard with your hand by applying pressure away from port while making sure not to bend any of the contacts.
    • Remove the 10mm PH#1 screw securing motherboard to device.
  14. Toshiba Satellite C55-A5140 Headphone jack Replacement: adım 14, 2 resimden 1. Toshiba Satellite C55-A5140 Headphone jack Replacement: adım 14, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Flip motherboard over, and using the precision tweezers, disconnect the two ribbon cables.
    • Pull motherboard free from device.
  15. Toshiba Satellite C55-A5140 Headphone jack Replacement: adım 15, 2 resimden 1. Toshiba Satellite C55-A5140 Headphone jack Replacement: adım 15, 2 resimden 2.
    • Locate headphone jack on bottom right corner of the motherboard.
    • Turn motherboard over and use soldering iron and wick to melt and remove solder from 4 points holding headphone jack to the motherboard
    • Pull headphone jack from motherboard using tweezers.
    • A soldering iron can reach temperatures up to 650° F. Only perform this step if you are comfortable operating a soldering iron. Use proper protection equipment to avoid serious injury such as burns. If you are unsure how to solder, use this guide for help How To Solder and Desolder Connections.
Sonuç
Bir başkası bu kılavuzu tamamladı.
1Rehber Yorum
Whats the jack model n please? I want to buy it in advance.
Michal Sovcik - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 26
Her zaman: 3,588
