Ana içeriğe geç
Toshiba Satellite C55-A5302 Keyboard Replacement
Nicole Hague
Nicole Hague ve başka bir katkıda bulunan
En son July 16, 2023 tarihinde güncellendi
15 - 20 dakika
Orta
This guide will teach you how to disassemble the device in order to replace the Keyboard.
Neye ihtiyacın var
Aletler
  1. Toshiba Satellite C55-A5302 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Power down the laptop and remove all power cords. After this is done, turn the laptop over.
  2. Toshiba Satellite C55-A5302 Keyboard Replacement: adım 2, 1 resimden 1.
    • Slide the battery latches outwards away from the center of the device.
    • The right latch will slide to the right, and left latch to the left.
  3. Toshiba Satellite C55-A5302 Keyboard Replacement: adım 3, 1 resimden 1.
    • Lift and remove the battery from the device.
  4. Toshiba Satellite C55-A5302 Keyboard Replacement, Hard Drive: adım 4, 1 resimden 1.
    • Use the Phillips #1 screwdriver to unscrew the thirteen screws on the back of your device.
  5. Toshiba Satellite C55-A5302 Keyboard Replacement: adım 5, 1 resimden 1.
    • Remove the middle plastic cover to expose the hard drive.
  6. Toshiba Satellite C55-A5302 Keyboard Replacement: adım 6, 1 resimden 1.
    • Using the Phillips #1 screwdriver, remove the two screws holding the hard drive in place.
  7. Toshiba Satellite C55-A5302 Keyboard Replacement: adım 7, 1 resimden 1.
    • Remove the three screws using the Phillips #1 screwdriver.
    • Insert you fingers into the rubber ends and gently pull the hard drive out of the device.
  8. Toshiba Satellite C55-A5302 Keyboard Replacement, Optical Disk Drive: adım 8, 1 resimden 1.
    • Use the Phillips #1 screwdriver to remove the two screws under the hard drive.
  9. Toshiba Satellite C55-A5302 Keyboard Replacement: adım 9, 1 resimden 1.
    • Use a metal spudger and run it along the edges of the computer to take off the plastic back cover. (Starting near a port usually allows more space for the spudger to be inserted)
  10. Toshiba Satellite C55-A5302 Keyboard Replacement: adım 10, 1 resimden 1.
    • Slowly work from one end to the other to lift the back cover off.
  11. Toshiba Satellite C55-A5302 Keyboard Replacement: adım 11, 2 resimden 1. Toshiba Satellite C55-A5302 Keyboard Replacement: adım 11, 2 resimden 2.
    • Grab hold of the optical drive and elevate it slightly and remove it from the computer.
  12. Toshiba Satellite C55-A5302 Keyboard Replacement, Keyboard: adım 12, 2 resimden 1. Toshiba Satellite C55-A5302 Keyboard Replacement, Keyboard: adım 12, 2 resimden 2.
    • Using your thumb, apply a light amount of pressure to the underside of the keyboard until it pops out a bit.
  13. Toshiba Satellite C55-A5302 Keyboard Replacement: adım 13, 1 resimden 1.
    • Using the metal spudger, carefully pry up the edges of the keyboard.
  14. Toshiba Satellite C55-A5302 Keyboard Replacement: adım 14, 1 resimden 1.
    • Shift the small tabs on either side of the ribbon outwards to release the end of the ribbon.
    • Gently remove the keyboard from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 13
Her zaman: 664
