Ana içeriğe geç
Toshiba Satellite C55-B5200 Hard Disk Drive Replacement
Pablo Andrade
Pablo Andrade ve 2 diğer katkıda bulunanlar
En son July 23, 2023 tarihinde güncellendi
5 dakika
Kolay
A hard drive replacement guide for a Toshiba Satellite C55-B5200 laptop.
Neye ihtiyacın var
Aletler
  1. Toshiba Satellite C55-B5200 Hard Disk Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the laptop off and remove all sources of power.
    • Flip the laptop over so that way the bottom is facing towards you.
    • Remove the two 6.6mm Phillips #0 screws from the battery.
  2. Toshiba Satellite C55-B5200 Hard Disk Drive Replacement: adım 2, 1 resimden 1.
    • Pull the battery out of the laptop.
  3. Toshiba Satellite C55-B5200 Hard Disk Drive Replacement, Hard Disk Drive: adım 3, 3 resimden 1. Toshiba Satellite C55-B5200 Hard Disk Drive Replacement, Hard Disk Drive: adım 3, 3 resimden 2. Toshiba Satellite C55-B5200 Hard Disk Drive Replacement, Hard Disk Drive: adım 3, 3 resimden 3.
    • Remove the two 4.6mm Phillips #0 screws from disk drive.
    • Lift the disk drive and pull out to remove.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Pablo Andrade
1.081 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G1, Nance Spring 2018 USF Tampa, Team S3-G1, Nance Spring 2018 üyesi
USFT-NANCE-S18S3G1
4 Üyeler
22 adet Kılavuz yazıldı
2 Yorum
Pablo, you didn’t mention that you must remove all the screws to get at the hard drive. What a pain. Other satellites have compartments the c55 that i have you must take every screw out as the back is one piece. Thanks for the instructions.
stevesd619 - Yanıt
Dónde puedo comprar el disco duro de una laptop toshiba satellite C55
Dulce Martinez - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 19
Her zaman: 4,680
