Ana içeriğe geç
Toshiba Satellite C55-C5268 Battery Replacement
Greg Smith
Greg Smith ve 6 diğer katkıda bulunanlar
En son December 14, 2022 tarihinde güncellendi
45 saniye
Kolay
The battery of the Toshiba Satellite is located on the bottom of the laptop, near where the screen attaches to the base. It is held in place by two Phillips head screws which need to be removed in order to remove the battery. The iFixit toolkit size PH1 bit will fit.
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
  1. Toshiba Satellite C55-C5268 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Unplug and power off the laptop.
    • Unscrew the two 9 mm Phillips #1screws holding the battery in place.
  2. Toshiba Satellite C55-C5268 Battery Replacement: adım 2, 2 resimden 1. Toshiba Satellite C55-C5268 Battery Replacement: adım 2, 2 resimden 2.
    • Grab the battery and pull it away from the laptop to remove it.
    • This doesn't require a lot of effort, so you don't have to pull too hard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Greg Smith
347 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-1, Catania Fall 2016 UMass Dartmouth, Team 4-1, Catania Fall 2016 üyesi
UMASSD-CATANIA-F16S4G1
2 Üyeler
12 adet Kılavuz yazıldı
2 Yorum
Thanks, l think my battery is dead, charged it for 12 hours and base never got hot, not charging, right? Computer does not come on at all.
bribocall - Yanıt
Hello! i have TOSHIBA SATELLITE C55-B1065 Laptop and i’m wondering what is the good battery i should buy ?
sana aissaoui - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 22
Son 30 gün: 77
Her zaman: 17,768
