Ana içeriğe geç
Toshiba Satellite C55D-A5108 Heat Sink Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C55D-A5108 Heat Sink Replacement, Battery: adım 1, 1 resimden 1.
    • Flip over the device so that the model stickers are facing up.
  2. Toshiba Satellite C55D-A5108 Heat Sink Replacement: adım 2, 1 resimden 1.
    • Move the right notch to the unlock position by sliding it to the right.
  3. Toshiba Satellite C55D-A5108 Heat Sink Replacement: adım 3, 1 resimden 1.
    • Hold the left notch in an unlocked position with one hand and use the other hand to slide the battery out.
  4. Toshiba Satellite C55D-A5108 Heat Sink Replacement, Hard Drive: adım 4, 1 resimden 1.
    • Remove the Phillips #0 screw from the memory cover.
  5. Toshiba Satellite C55D-A5108 Heat Sink Replacement: adım 5, 1 resimden 1.
    • Grasp the side of the hard drive opposite the circular battery, and carefully pull out the drive by moving it away from the circular battery.
  6. Toshiba Satellite C55D-A5108 Heat Sink Replacement, Back Cover: adım 6, 3 resimden 1. Toshiba Satellite C55D-A5108 Heat Sink Replacement, Back Cover: adım 6, 3 resimden 2. Toshiba Satellite C55D-A5108 Heat Sink Replacement, Back Cover: adım 6, 3 resimden 3.
    • Remove the 16 screws holding the back cover with a Phillips #0 screwdriver.
    • Pry the cover off with an opening tool.
    • Gently remove the cover with your hands and place to the side.
  7. Toshiba Satellite C55D-A5108 Heat Sink Replacement, Heat Sink: adım 7, 2 resimden 1. Toshiba Satellite C55D-A5108 Heat Sink Replacement, Heat Sink: adım 7, 2 resimden 2.
    • Remove the four Phillips #0 screws from each corner of the heat sink.
    • Gently lift the heat sink out of the computer.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ryan Smith
187 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G5, O'Connell Fall 2019 UMass Dartmouth, Team S1-G5, O'Connell Fall 2019 üyesi
UMASSD-O'CONNELL-F19S1G5
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 277
