Toshiba Satellite C55D-B5206 Fan Replacement
Giriş
1. adıma gitThe fan of your Toshiba Satellite C55D device may malfunction at some point. If your constantly heats up shuts down, that indicates the fan has malfunctioned. This manual will provide a step-by-step guide to replace the fan,
Neye ihtiyacın var
Turn the laptop upside down so the battery faces upwards.
Use a Phillips #1 screwdriver to remove the two, 7 mm screws that secure the battery.
Use the screwdriver to remove the thirteen, 7 mm Phillips#1 screws from the bottom of the chassis.
Remove the three 7 mm Philips head screws by turning the screws counter clockwise.
Bir başkası bu kılavuzu tamamladı.
