Ana içeriğe geç
Toshiba Satellite C55D-B5206 RAM Replacement
David Amodei
David Amodei ve 4 diğer katkıda bulunanlar
En son January 25, 2024 tarihinde güncellendi
15 - 30 dakika
Orta
Madde imleri!
Daha iyi giriş
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
  1. Toshiba Satellite C55D-B5206 RAM Replacement, RAM: adım 1, 1 resimden 1.
    • First, flip the laptop over and use the J1 screwdriver (in the iFixit tool kit) to unscrew the 15 screws indicated in the picture.
    • Make sure to put your screws in a safe place to make sure they do not get lost.
  2. Toshiba Satellite C55D-B5206 RAM Replacement: adım 2, 1 resimden 1.
    • Once you take the screws out, take the battery off; it should slide off easily.
  3. Toshiba Satellite C55D-B5206 RAM Replacement: adım 3, 1 resimden 1.
    • Next, move around the edges of the computer with the metal spudger prying off the casing. You should hear clicks as you do this; this is not the casing breaking, it is just popping off.
  4. Toshiba Satellite C55D-B5206 RAM Replacement: adım 4, 1 resimden 1.
    • Then, carefully take off the back casing of the laptop and set it aside.
  5. Toshiba Satellite C55D-B5206 RAM Replacement: adım 5, 1 resimden 1.
    • This is where the RAM is located that you will be replacing.
  6. Toshiba Satellite C55D-B5206 RAM Replacement: adım 6, 1 resimden 1.
    • There are two clips holding the RAM in place.
    • You will need to hold both of them back to be able to safely remove the RAM.
    • Use plastic spudgers, as the metal spudgers pictured here are not ESD-safe.
  7. Toshiba Satellite C55D-B5206 RAM Replacement: adım 7, 1 resimden 1.
    • Gently remove the RAM and insert replacement.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
This guide was done wonderfully. My critique for your group is to be more specific with the direction of how to pull/place the components of the device. Your instructions were simple, yet clear. Great work.
Dan Hartzell - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 571
