Ana içeriğe geç
Toshiba Satellite C55D-C5106 Key Replacement
Laura Tamayo
Laura Tamayo ve başka bir katkıda bulunan
En son December 15, 2022 tarihinde güncellendi
5 dakika
Çok kolay
In the case you may need to replace a key on your Toshiba Satellite C55D-C5106 keyboard, this manual is meant to guide you along the process.
Neye ihtiyacın var
Aletler
  1. Toshiba Satellite C55D-C5106 Key Replacement, Key: adım 1, 1 resimden 1.
    • Open the laptop, turn it off, and remove any external power sources before you remove any keys.
    • Identify which key needs to be replaced and make sure you have an identical, functioning key on hand.
  2. Toshiba Satellite C55D-C5106 Key Replacement: adım 2, 1 resimden 1.
    • Wedge your ifixit opening tool underneath the non-functioning key.
  3. Toshiba Satellite C55D-C5106 Key Replacement: adım 3, 1 resimden 1.
    • Remove the key from the laptop.
Sonuç
Laura Tamayo
678 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G4, Leahy Spring 2019 USF Tampa, Team S1-G4, Leahy Spring 2019 üyesi
USFT-LEAHY-S19S1G4
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 19
Son 30 gün: 20
Her zaman: 258
